Go to Post You all have ample time to get your sleep in from the final day of nationals to the friday before kickoff. There should be no reason why anyone will need sleep for the next 6 weeks and then some. You all have had enough of sleep or hibernation, now its time to wake up and do some work =). - mtaman02 [more]
  #31   Spotlight this post!
Unread 20-01-2017, 17:12
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Team 449 Climber
Originally Posted by SuperBK View Post
Wait - there is a knot in the at the bottom end of the rope? Or, Are you planning to bring your own rope and its legal to have a knot at the bottom to grab onto?
https://firstfrc.blob.core.windows.n...ligibility.pdf
"The breakfast of champions!"
  #32   Spotlight this post!
Unread 21-01-2017, 22:59
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Thanks for posting your design.
If there is any concern about Versaplanetarys taking the load, you could go with half the gear reduction and a 1:2 chain sprocket ratio.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
  #33   Spotlight this post!
Unread 22-01-2017, 01:09
AKA: Eli Barnett
Yeah, I considered that earlier in the thread. We're really not that worried about it, though, given the loading and VexPro's documentation.
  #34   Spotlight this post!
Unread 25-01-2017, 18:14
JasdeepSadam JasdeepSadam is offline
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
JasdeepSadam is an unknown quantity at this point
So does the rope just wrap around around the rod? I was just wondering because we have a similar design and I wanted to know if you had anything special to keep the rope in place and wrapping around while keeping the robot relatively stable. THANKS
  #35   Spotlight this post!
Unread 25-01-2017, 19:34
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
One more question. What material did you use use for the rod? Did you buy it from AndyMark or McMaster-Carr? Thanks
  #36   Spotlight this post!
Unread 25-01-2017, 20:33
AKA: Eli Barnett
The rod material is from https://www.competitionrobotparts.com/
  #37   Spotlight this post!
Unread 25-01-2017, 22:14
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Without a ratchet how does it not come back down?
  #38   Spotlight this post!
Unread 25-01-2017, 23:24
AKA: Eli Barnett
There's a half-inch ratcheting wrench on the hex shaft.
