Go to Post If you are adult enough to be a participant in this program, then you are adult enough to act like an adult. - Beth Sweet [more]
Unread 25-01-2017, 18:53
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
Re: Building Commands at Runtime
I feel like this is probably a stupid question, but why not just send out something other than a command (e.g. a String) and then initialize the command after it's selected?
Unread 25-01-2017, 19:58
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
Same thing- using strings is less compact and is a bit more repetitious. Instead of having a massive if/else/switch complex for the strings, you can just get a fresh instance of the command and pass it along to the addSequential method. If you want to add or remove an option, you only need to edit what you add to the sendablechooser. If you use the sendablechooser in multiple different command groups, you need only one line instead of the whole if/else/switch chain.
The supplier also guarantees that each command group has a unique instance of a command.
*Also imo lambdas and method references are more readable and look more elegant
