Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 25-01-2017, 22:08
elijah1111's Avatar
elijah1111 elijah1111 is offline
FRC #4601 (Circuit Birds)
Rookie Year: 2015
elijah1111 is an unknown quantity at this point
Exclamation Driver station installation problems
Hey every one, while updating to the new driver station we have had numerous problems getting it to work, we keep getting this error api-ms-win-crt-runtime-l1-1-0.dll is missing or something along those lines. I have attempted copying the whole update suite, downloading online, and even disk installation nothing works. Little bit of googling suggested an OS incompatibility, which does not seem right. The install worked fine on my personal windows 10 laptop, but our drive computer is a Windows 7. Any suggestions on how to fix this?
Elijah
4601 Circuit Birds
Unread 25-01-2017, 22:12
Re: Driver station installation problems
That .dll comes in a Windows update.
Run Windows Update on the PC for a few days until it stops finding more stuff to update.
Unread 25-01-2017, 23:19
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
If you run into Windows update taking a long time (days) to update packages, this procedure may help:
from: http://superuser.com/questions/95196...ng-for-updates
(1) Download the following updates for windows 7:
for 32-bit
https://www.microsoft.com/en-us/down....aspx?id=46827
https://www.microsoft.com/en-us/down....aspx?id=53335
for 64-bit
https://www.microsoft.com/en-us/down....aspx?id=46817
https://www.microsoft.com/en-us/down....aspx?id=53332
(2) Stop 'Windows Update' from the Service Manager
Type 'services' in the windows start menu search box.
Launch 'services'
Find 'Windows Update' in the service list and stop it.
(3) Install Windows6.1-KB3020369 by running it to see if it is needed or not.
(4) If it was needed, after the reboot, do step (2) again.
(5) Install Windows6.1-KB3172605.
from: http://stackoverflow.com/questions/3...ft-office-file
(6) Run 'windows update', check for and install any important updates, repeat until there are none left.
(7) Run 'Uninstall Programs' from the Control Panel
select 'Microsoft Visual C++ 2015 Redistributable', x86 and x64 each and uninstall them
select 'National Instruments Software' and uninstall all products as well.
(8) Install Driver Station (C++/Java) or NI Labview
Unread 25-01-2017, 23:23
I haven't needed to uninstall anything, just apply the Windows updates.
Is there a reason you found you had to uninstall those products?
Unread 26-01-2017, 15:06
elijah1111's Avatar
Rookie Year: 2015
Smile Re: Driver station installation problems
Problem solved it was Microsoft visual studio. It needed an update.
