Go to Post Most members of the CD community are happy to help one another. But searching before you post is standard forum etiquette... - KathieK [more]
Unread 25-01-2017, 21:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: What autonomous modes will teams have?
Originally Posted by jeremylee View Post
Placing the other 2 gears...
And what's happening to the pre-loaded gear on the hopper auto bot?
Unread 25-01-2017, 22:16
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Question Re: What autonomous modes will teams have?
Originally Posted by Lil' Lavery View Post
I'm certain there will be teams capable of placing two gears on lifts before the end of autonomous. I am less certain they will do so with enough time for the second gear to be placed on a rotor and spun up for autonomous bonus points.
But wouldn't having an auto mode for 2 gears violate A01 "Behind the lines. During AUTO, DRIVE TEAM members in ALLIANCE STATIONS and LOADING LANES may not contact anything in front of the STARTING LINES, unless for personal or equipment safety." and since you can only have one gear on your robot...
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 25-01-2017, 23:38
niklas674's Avatar
niklas674 niklas674 is offline
Mecanum+drive=A bad idea
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of light
I think the smart move for that robot would be to place that gear on their robot so it'll fall off or to where it's in their gear mechanism. No point in having to do another cycle of you don't have to.
My views do not represent the views of my team
Unread 25-01-2017, 23:55
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Here is where I would assume most teams with a consistent hopper auto would be semi-powerhouses. Maybe not on par with 254 or 1114, but they would definitely know what they're doing. That being said, chances are a team with hopper auto capability will most likely also have gear capability, which would mean that at some point in the match, they would be placing that gear, at their convenience. No point in knocking it to the floor only for a floor gear intaker to pick up later, when the hopper bot will most likely be able to score it later anyway.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 26-01-2017, 00:09
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by GeeTwo View Post
I'm going to come at it the other way - identify autonomous goals and prognositcate as to how many teams will achieve them. In order from most to least,then:
60%-70% of teams will be able to cross the baseline most of the time by the end of their first event, 90%-95% of CMP teams will do so most of the time.
20%-30% of teams will deliver an auto gear at three or more qual matches in their first event. 45% to 55% at CMP.
Less than 3% of teams will ever deliver two auto gears in the same match. Less than 1% will do it three matches in a row.
15%-25% of teams will score at least one kPa autonomously in three matches at their first event.
3% to 7% of teams will score at least five kPA autonomously in three matches at their first event.
1% to 2% of teams will score at least 10 kPa autonomously in three matches at their first event.
I mostly echo these thoughts for autonomous.
I think less than 1% of teams will ever do a 2 gear auto. 900 will, because the vision system demands it, but from a strategic perspective it makes no sense if you can do anything with fuel, since a team with resources to score 2 gears should be attempting the 40+ point boiler auto instead. We will mainly see it on Einstein when a partner can already do the super boiler auto (either that or we see a coordinated double hopper auto... and CD will lose its mind).
I will predict we never see the 2nd rotor started in autonomous except at Champs or a District Champ event.
I do think 1-2% of teams will score a gear and at least one kPa autonomously in three matches at their first event.
Unread 26-01-2017, 08:14
pmattin5459's Avatar
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Does two gears actually give you any more points than one? I believe that you need one gear to get the first rotor spinning, and then two for the next rotor, for a total of 3 if you want a 120pt auto, and you can't use the gear included in the airship until teleop begins. Certainly a two gear auto is better than just one, as it gives you a nice head start on one of your rotors (that can have its second gear slotted in as soon as teleop begins) but doesn't really give you those auto bonus points for the second rotor.
Unread 26-01-2017, 08:18
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
1.) score 2 gears and cross
2.) score a gear and 10 high goals
3.) score 8-10 high goals and cross
4.) score 10 low goals
It isn't shiny enough.
Unread 26-01-2017, 11:11
The Arizona Mentor
AKA: Andrew
It doesn't, you are correct that you need all 3 gears for the 2nd rotor bonus. This is part of why the consensus is it will almost never happen, the value of a 2 gear auto is less than a hopper dump + boiler auto which has the potential for 40+ points if perfected. 2 gear auto only makes sense to consider if you can't handle fuel in auto or someone else can better, and even then the coordination to pull it off is difficult.
Unread 26-01-2017, 20:00
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
It would be interesting to see a team with a 2 gear auton partner with a team that can score 40+ kPa autonomously (in the high goal), and a 3rd bot that can place a single gear, getting a total of (check my math) 175 points and 1 RP in auton (assuming all 3 robots cross the baseline at some point, whether to access the hopper or to hang a gear). I realize that this is a perfect scenario, a lot of variables involved (including lightning fast pilots) and although it may not be probable, I think it is possible, at least at the Championship level. At any rate it would be great to see.
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Unread 26-01-2017, 20:10
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
I'm going to be honest here, I don't think we will see very many (if at all) 2 gear autos over the course of the season, especially at high levels. There are simply easier ways to get the three gears up in auto if you really wanted to, and having to have a team drop a gear and have another team pick it up consistently will be much harder.
My FRC History:
Unread 26-01-2017, 20:20
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Gear + 40kpa auto from the elite teams.
Unread 26-01-2017, 20:31
AKA: Patrick Mattin
Rookie Year: 2015
Precisely. It makes sense for a high level team to do both fuel and gears in auton rather than ignoring the 20 point bonus (and progress towards the 3rd and 4th rotors) that their alliance gets from doing a 3 gear auto (with the 2nd and 3rd picks getting a gear each) or hoping for an alliance partner capable of a 2 gear auton.
Unread 26-01-2017, 21:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If there's a team that can place a gear on the lift with sufficient time to start a rotor, open a hopper, receive and index the hopper's balls, and shoot 40+ balls with enough time for them to be processed before the end of autonomous I'll be beyond impressed. The amount of teams capable of that will be something we can count on one hand.
Unread 26-01-2017, 23:16
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
Originally Posted by Poseidon5817 View Post
What maximum autonomous capability do you think various levels of robots will have?
  1. Elite teams (Top 1%)
  2. Alliance captain teams
  3. Median teams
  4. Low-level teams
Do you think elite teams will be able to score multiple gears in autonomous? Will low-level teams be able to consistently score a single gear? I'd love to hear your thoughts.
1. Place a gear, dump a hopper, go shoot all the hopper balls. (Is that all legal? I haven't paid close enough attention, because I'm not part of a 1% team.)
2. Place a gear at the beginning of the season, with success about 1/3 of the time. Place a gear and shoot their preloaded balls by the end. (This is where I'm aiming for.)
3. Shoot their preloaded balls at the beginning of the season. Attempt and occasionally manage a gear by the end.
4. Drive forward, or do nothing.
I think placing a gear during autonomous is something a lot of people underestimate for difficulty. Maybe not. Computer vision is a lot easier and better than it used to be, and more people, students and mentors alike, know a lot more about it than they used to. That will greatly improve success rates.
This technology race is positively scary some days.
Unread 26-01-2017, 23:20
niklas674's Avatar
Team Role: CAD
Rookie Year: 2015
Number 1 is legal.
