Go to Post Being rude is easy. Being a compassionate human being takes work. - Joe Johnson [more]
Unread 25-01-2017, 22:37
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
OpenCV VideoWriter Raspberry Pi
Hello everyone,
My team is trying to run vision tracking on our Raspberry Pi for the lifts. We wanted to record the video output so we could debug in real time just in case something went wrong during a match, but OpenCV doesn't run the commands related to the VideoWriter class. There aren't any errors that come from the shell, but the program literally skips over those lines of code. Has anyone else had any problems similar to this on the pi? Do you know how to fix this error?
Thanks,
Jonathan Daniel
Head Programmer
Fernbank LINKS Robotics
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 25-01-2017, 22:57
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: OpenCV VideoWriter Raspberry Pi
The wpilib opencv artifacts are not compiled with non-free codec support. Because of this, both VideoWriter and VideoCapture do not support reading or writing from encoded streams such as Avi or mpeg-4. You will need to write individual frames as jpegs using imwrite if you want to write frames.
Team 4488 - Mentor 2013-2016
Unread 25-01-2017, 23:04
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
OK, thanks!
Unread 26-01-2017, 11:08
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
Does it work using MPJEG as the codec type for VideoWriter? We've done that before as an alternative to tying up CPU cycles trying to do H264 or whatever encoding on the fly.
Unread 26-01-2017, 13:48
Yes, it should be able to do mjpeg, since it does support jpeg images. I have not explicitly tested this however.
Unread 27-01-2017, 15:11
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
Be careful with MJPEG for recording on an embedded arm device. MJPEG is bitrate hungry and ranges anywhere from 10x to 20x larger than something like h264 or v8. This can easily saturate your SD card's throughput.
WebM might be an option. Another possibility is to use the v4l2-loopback and gstreamer to record locally with x264 in a separate thread, while having your vision processing run on a forked stream.
