Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 25-01-2017, 22:50
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Polycord and polycord pullies
Anyone have a source or two for polycord or polycord pullies. The one I have found is on back order at thw quantity we want...
Unread 25-01-2017, 22:52
Maldridge422's Avatar
Maldridge422 Maldridge422 is offline
I was on a different team in 2013.
AKA: Matt Aldridge
FRC #0619 (Cavalier Robotics)
Maldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant future
Re: Polycord and polycord pullies
We got belts from McMaster earlier this season.
Unread 25-01-2017, 22:55
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
http://superiorbands.com/polycord.html has a great selection of poly cord in different diameters and you can buy up to 500ft. or more. The expedite shipping also. As for McMaster Carr they should have pullies ready to order? We just ordered a few.
Team member 2004-2008
Team mentor 2008-20XX
http://www.team1708.com/
"Education is a powerful tool. Always use it to better someone else's life"
Unread 25-01-2017, 23:02
Billfred's Avatar
Billfred Billfred is offline
Originally Posted by Maldridge422 View Post
This. I believe we bought 3/16" IIRC, solid core, clear (which was mostly a favor to me because orange has connotations where I'm from.)
We also bought UHMW rods, originally 2" but we found 1.75" was closer to what we needed. One of our mentors has a lathe and has been working on cutting them into 3" pulleys with two grooves apiece. Once bored to the correct round size, I take them to work and broach them for 1/2" hex on the arbor press there. We're then sliding them onto 1/2" churro, as the finished pulleys are a little easier to get on and off compared to regular hex stock; we may switch for the final production robot.
(Full disclosure, I work at AndyMark that sells the 1/2" hex broach.)
(And before anyone goes "but where are the kids in all this?": We put them to work as much as possible, but this is a case where the necessary machines and tools aren't in the same town or even the same county as the school. The kids will be getting very good at polycord welding once the rollers are done!)
Unread 25-01-2017, 23:03
D_Price's Avatar
Engineer/Mentor
AKA: Derek
Polycord welding is an art form and takes time (and alot of trial and error) to get right.
Unread 25-01-2017, 23:15
Billfred's Avatar
Agreed, though I've done it on other teams in 2009 and 2012 so we should have more trial and less error.
Unread 25-01-2017, 23:58
Best Available Data
FRC #1778 (Chill Out!)
In my experience, getting both ends hot by sticking them in front of a heat gun until they get a little melty and then smooshing them together & holding them together until they cool down has been sufficient. What are you doing that requires lots of trial and error?
See Art Dutra's method from 2009 that has always served me well.* That was just a few years ago, right?
*Don't do 10% shorter. 3-5% is sufficient and much easier.
Unread 26-01-2017, 00:14
Bob Steele's Avatar
AKA: Bob Steele
We use hex shaft and cut the disks for the poly cord out of 1/8 polycarbonate. We cut them on the waterjet but you could probably find a different way to cut them and then use a hex broach for the hole. (These are for driven pulleys or idler pulleys on a live axle) We are presently using 3 - 1/8 inch center pieces and two 1/8 inch outer pieces with a difference of 3/16 so that the round drive belt is 1/16 proud. This gives us a 3/8 spacing in the middle of the pulley with the two side plates....
Are you using a dead axle for them or a live axle? idlers can just spin on a dead round axle (with or without bearings if you use something slippery like UHMW for the pulleys.... )
In the past we have also used a piece of PVC pipe and glued on more PVC pipe cut from connectors as spacers between the belts. We put a hub inside the pipe on both ends and ran an axle through it. This worked OK but was not optimal although it was pretty cheap to make. The belts all drive together but you will have to put a sprocket on one of them connected to the motor (with chain) to put power to the whole assembly.
Unread 26-01-2017, 00:47
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Back in 2012 we used 1.5" OD x 1/16 wall round aluminum tubing with strips of roughtop tread as spacers. We riveted in endcaps made of nylon and tapped them for 1/4-20 bolts, which served as the axles. The powered rollers had a hex broach on one side instead. I want to say we gave 6% stretch on the polycord. We used the green belts, which are supposed not to catch and come off track because of their rough surface, and in my experience that's pretty much true. That system worked like a charm forever.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 26-01-2017, 00:59
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
if you have access to a lathe nothing beats solid delrin for polycord. they work great with dead and live axles. delrin lubricates itself. if you need to drive it its also super easy to hex broach. machine it to the desired diameter then notch it for the poly cord to ride in.
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 26-01-2017, 06:23
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
4063 3D prints all of our polycord pullies.
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 26-01-2017, 08:13
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
In my limited experience I used a hot knife to weld the polycord. Heat up the hot knife, press both ends of the polycord on opposite sides of the knife to get them nice and gooey, and then slide the ends off the hot knife and into each other. Works splendidly if you don't overheat the polycord
It isn't shiny enough.
Unread 26-01-2017, 08:42
D_Price's Avatar
Engineer/Mentor
AKA: Derek
That is exactly how we do it also. As in rephrasing my prior post, back when I was a student there in 2005-2008 there wasn't much documentation (or we just didn't have the knowledge to look it up) therefore having way more trial and error. Now it is smooth sailing.
Unread 26-01-2017, 09:53
Billfred's Avatar
Art's method is sound, and how 2815 did their polycord runs. He did omit the last step: after it's cooled for that half-hour, stretch it as hard as you can. If it breaks, you didn't do it right and need to do it again.
