Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
  #31   Spotlight this post!
Unread 20-01-2017, 17:12
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Team 449 Climber
Originally Posted by SuperBK View Post
Wait - there is a knot in the at the bottom end of the rope? Or, Are you planning to bring your own rope and its legal to have a knot at the bottom to grab onto?
https://firstfrc.blob.core.windows.n...ligibility.pdf
"The breakfast of champions!"
  #32   Spotlight this post!
Unread 21-01-2017, 22:59
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Thanks for posting your design.
If there is any concern about Versaplanetarys taking the load, you could go with half the gear reduction and a 1:2 chain sprocket ratio.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
  #33   Spotlight this post!
Unread 22-01-2017, 01:09
AKA: Eli Barnett
Yeah, I considered that earlier in the thread. We're really not that worried about it, though, given the loading and VexPro's documentation.
  #34   Spotlight this post!
Unread 25-01-2017, 18:14
JasdeepSadam JasdeepSadam is offline
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
JasdeepSadam is an unknown quantity at this point
So does the rope just wrap around around the rod? I was just wondering because we have a similar design and I wanted to know if you had anything special to keep the rope in place and wrapping around while keeping the robot relatively stable. THANKS
  #35   Spotlight this post!
Unread 25-01-2017, 19:34
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
One more question. What material did you use use for the rod? Did you buy it from AndyMark or McMaster-Carr? Thanks
  #36   Spotlight this post!
Unread 25-01-2017, 20:33
AKA: Eli Barnett
The rod material is from https://www.competitionrobotparts.com/
  #37   Spotlight this post!
Unread 25-01-2017, 22:14
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Without a ratchet how does it not come back down?
  #38   Spotlight this post!
Unread 25-01-2017, 23:24
AKA: Eli Barnett
There's a half-inch ratcheting wrench on the hex shaft.
