Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 26-01-2017, 08:42
hmarch5421 hmarch5421 is offline
FRC #5421
hmarch5421 is an unknown quantity at this point
Java Programming - Cannot Deploy
Hey all,
I'm having some trouble deploying Java code to the RIO. I've reimaged the RIO, reinstalled the JDK, reinstalled eclipse, reinstalled WPIlib, and am still having the issue. The error was an ImageRegExFail on RIO image matching. Also, the deploy takes forever compared to last year's.
Thanks,
5421
Unread 26-01-2017, 09:03
ben47955 ben47955 is offline
FRC #3996 (RIKITIK)
ben47955 is an unknown quantity at this point
Re: Java Programming - Cannot Deploy
What is your OS ?
Do you see connection in driverstation ?
When you said RIO, do you said roboRio or the old RIO ?
Unread 26-01-2017, 09:15
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Check you're using the 2017 Version of the RoboRIO imaging tool.
If you're absolutely sure it's correct, a quick google search yields this thread
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 26-01-2017, 09:58
FRC #5421
both macOS 10.12 and Windows 10
Yes Driver's station has comms.
RoboRIO
Unread 26-01-2017, 10:02
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
RoboRIO
When you connect through the driver station, it should tell you which image version is installed on the roboRIO. Make sure this is 2017 v8. Also make sure you've updated your Eclipse plugins. In the latest update, there might have been a change that affected it (- Fix RoboRIO image version detection in presence of EOL in configuration).
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
