Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
View Poll Results: How will you be handling Gears?
We are building a Gear Ground Pickup 85 28.52%
We are building a Gearage that can only eject a Gear when the Pilot lifts it out. 89 29.87%
We are building a Gearage that can eject Gears without waiting for the Pilot. 113 37.92%
We forgot to read the manual to realize how important Gears are, so we won't be doing them. 11 3.69%
Voters: 298. You may not vote on this poll
Unread 26-01-2017, 03:21
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Value of a Gear Ground Pickup
There has been a lot of scattered discussion regarding the pros and cons of having a Gear ground pickup. Now that teams (hopefully) have started finalizing designs and are in the process of building, I'm curious to know how many teams opted to go with a Gear ground pickup, and why?
Given that many teams are designing a "Gearage" which are essentially big boxes that can only eject a Gear when the pilot lifts the spring, how valuable can a Gear ground pickup be?
I would call it likely that a majority of teams won't have the ability to eject a Gear without help from a Pilot. I would also call it likely that most Gearages will do a good job of containing Gears, and there will be relatively few Gears on the floor that weren't placed there intentionally.
I think a Gear ground pickup does open up some interesting strategic possibilities, but are these worth the resources, time and effort to develop vs. a simple box?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 26-01-2017, 03:35
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Value of a Gear Ground Pickup
Since no one out there really cares too much what 1339 is planning (not like tier one teams, at least), I'll go ahead and tell you. We have designed for floor pickup of GEARS on the opposite end of the robot from GEAR placement. We recognized that FUEL would be the primary focus of most top teams, but we wanted to take a different approach that would play to our strengths, and would potentially play a rare or unique role. I don't know if GEARS on the floor will be common or not, but I suspect that low level teams will be focusing on GEARS, and that the drop areas will be when they are loaded and unloaded, potentially cutting off future scoring chances. A reliable and fast floor pickup may end up being a clutch player. We also considered the possibility of a two or three GEAR autonomous, though we know that's remote. Who knows? The game is yet to be played, and floor pickups might be a dark horse.
http://www.angelbotics.com
Remember why you're doing this.
Unread 26-01-2017, 06:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by mrnoble View Post
...Who knows? The game is yet to be played, and floor pickups might be a dark horse.
^^ We're doing just about the same thing for the same reasons. We started with a "lift it out" prototype, though we're working to have a "gear pusher" in a week or so to push the gear home against the lift and at least the bottom parts of a floor pickup by bag day
That said, climbing is more important than the gear upgrades.
Unread 26-01-2017, 08:15
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
We're not investing in one for simplicity's sake, but I expect them to be valuable both for helping allies with preload gears (2 gear autons!) and with drops. While I still can't envision teams often dropping gears that are inside their gear funnels, some teams will--at least initially--struggle with loading station lineup. Even if it doesn't happen in many matches, an opponent dropping a gear at their loading station is a massive gift that most alliances won't be able to take advantage of. We'll also see some fumbles at the airship even from passive lifts, for instance with drivers pulling away too soon or gears slowly falling off springs and not landing back in the funnel.
Point being, as some passive frisbee loaders demonstrated in 2013, FRC matches ensure sufficient failure modes even for electromechanically simple mechanisms. It's hard to predict how common they'll be at your particular qual matches, but they're highly valuable to pickups when they do. Good luck to you!
EDIT: Ground pickups and their allies (or whoever) may also be able to force fumbles at the airship, hitting robots while they're around the peg to release or have their pilot lift. I still envision these as being difficult to pick up and steal given the sight lines, but I guess could camera work and field traffic strategy may be able to negate that. The ceiling for useful complementary technologies to a gear floor pickup is quite high.
Unread 26-01-2017, 08:59
Athos's Avatar
Athos Athos is offline
Athos is an unknown quantity at this point
Each alliance will have 21 gears available (18 from loading station + 3 from autonomous). An alliance would have to drop 10 gears before they would need the floor pickup to finish the airship.
Having seen what method many teams are using for holding gears, I don't expect alliances to drop enough gears to make sacrificing other aspects worth having the ground pickup. It will cost packaging space and build time, things that could be used to make or improve a shooter, climber, hopper, or fuel pickup. Assuming that it's faster than getting a gear from the human player, it also makes an easy target for defense while picking up a gear anywhere other than the loading station.
Unread 26-01-2017, 09:07
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
From a timing aspect, while it takes less time to actually intake a gear from the human player, the time you waste driving there and back pretty much makes up for that. That, combined with the fact that a gear dropped in front of a lift may effectively disable that lift, makes being able to pick up gears from the ground a nice ability. My team is not prioritizing this because we are already doing a lot of other things, but I definitely think this will be a favorable attribute come alliance selection.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 26-01-2017, 09:14
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
I think the during quake a robot that can pick up gears off the ground will be fairly valuable due to robots dropping Hera's in bad places. This will become less useful in elims or district champs due to team's refining their holders and deployers and practicing deploying gears for at least 2 comps. The ground pickup may not be needed at all in later elims assuming that the robot with ground pickup can also accept Hera's from the station without having to have them drop out.
Unread 26-01-2017, 09:23
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
At low levels gears will be dropped, but it won't be worth the time for a low level robot to attempt to pick up the gears.
At a medium level, gears will be occasionally dropped and an intake might be valuable.
At high levels gears will rarely be dropped, and might be valuable to be picked up by high level robots, but it's doubtful.
Gear pick ups might be valuable at some lower level regionals that are carried by medium-high teams, but that is the only situation I see them maybe being viable.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 26-01-2017, 09:25
mrnoble's Avatar
teacher/coach
We are not doing a lot of other things. Low, fast, strong pushing, stable, and focused on quick gears. Climbing as well, but no FUEL. We've often made the mistake of holding on to the dream of doing it all in the first week of designing, but this year we were able to let it go, and be at peace with our limitations. Personally, I'm very glad that we did.
Unread 26-01-2017, 09:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Autonomous.
Unread 26-01-2017, 09:38
Billfred's Avatar
Billfred Billfred is offline
We racked our brains on this one, but we couldn't justify the space commitment in our strategy. So we won't go from floor to peg, but we may come up with a way to escort floor gears closer for a partner that can.
Unread 26-01-2017, 09:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I wonder how gear pickups will work when the gear is supported by the sea of fuel.....
I do expect that we will need to practice clearing dropped gears from in front of the chutes. And lifts.
Unread 26-01-2017, 09:48
mrnoble's Avatar
teacher/coach
I will add that we figured out sufficient geometry to incorporate both a floor GEAR pickup and a FUEL hopper into the robot, though we are forgoing FUEL altogether. My point is that it wouldn't be impossible to do both.
Unread 26-01-2017, 09:49
Noudvanbrunscho's Avatar
Noudvanbrunscho Noudvanbrunscho is offline
Scout mentor
FRC #4481
Noudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the rough
I hope to see some ground intakes for gears, combined with an intake for fuel. I think it's very possible and very useful.
2015 - Team Spirit Award (Tesla-Archimedes Division)
2015 - Engineering Inspiration (Virginia)
2015 - Finalist (Virginia)
2014 - Imagery Award (Newton Division)
2014 - Engineering Inspiration (North-Carolina)
2013 - Rookie All-Star (North-Carolina)
Forty fooouuuuurrrr --- Eighty ooooooonnnnneeee!
Unread 26-01-2017, 09:51
Scout mentor
FRC #4481
I'm going to keep an eye on you! Good luck
