Go to Post Welcome to FIRST. You've never seen anything like this. - Aignam [more]
Go Back   Chief Delphi > Technical > CAD
Unread 25-01-2017, 21:46
Ngang's Avatar
Ngang Ngang is offline
FRC #2265 (Fe Maidens)
Team Role: Electrical
Ngang is an unknown quantity at this point
Thread on Signal Light?
Hi, I'm trying to design a mounting device to hold my team's signal light. Does anyone know what the threading on the signal light is?
Unread 25-01-2017, 21:51
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: Thread on Signal Light?
Your best bet would be to drill a hole slightly larger than the diameter of the threaded part of the signal light and use the nut that comes with the light to secure it.
Unread 26-01-2017, 07:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It doesn't appear to be on Rockwell's product page. Time to break out the calipers!
Unread 26-01-2017, 09:36
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
The robot signal light is designed to be mounted through a 22.5mm (.885in) hole.
(source)
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 26-01-2017, 09:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I wonder if it's 1/2" NPT?
