Re: TBA-API to end all TBA-APIs. (Java)
This would be really cool if I used Java. I'm not very good at it myself, so I've been using requests in Python for my TBA pulls, it makes things pretty user friendly. If I ever make the switch I'll be sure to keep this in mind. Thanks for posting.
Are you using a certain library or just urllib requests? I tried using the Python library recommended on the API docs by TBA but kept on getting a 403 error. Apparently they're blocking calls without a User-Agent.
Yeah that didn't used to be the case, but then we put everything behind Cloudflare, which apparently requires a user agent to be set. Must have broken that library.
I recommend the pip install since it's really easy. If you don't have pip the walk through is pretty good. PM me and I can send you some sample code, I don't want to derail this thread too much. |
