Go to Post ANY team is capable of producing a winning design. This does NOT require anything more than brainpower, and time. - Racer26 [more]
Unread 26-01-2017, 13:22
jamergamer jamergamer is offline
FRC #6323
jamergamer is an unknown quantity at this point
Exclamation Minimum battery voltage
Hi, We are rookie team 6323. Quick battery question...
Given that we can see the current battery voltage in the driver station, at what voltage should we swap batteries to ensure their longevity? Please consider the idle voltage vs driving full speed voltage.
Unread 26-01-2017, 13:26
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Minimum battery voltage
To know for sure, check the battery with a Battery Beak, but ~12.3 volts idle seems good if you're trying to ensure longevity and have enough batteries to swap in and out.
Unread 26-01-2017, 13:28
Billfred's Avatar
Billfred Billfred is offline
At competitions: Before every match--you don't have enough matches to afford blowing one to a dead battery.
At home: As voltages start dipping close to or below 12V at rest, we swap them. (Under load, the robot will naturally dip below 12V as amp draws increase.) My team's process for this is far from scientific and we invariably run them a little long, so we tend to use our oldest batteries for practice first since they're already less likely to be the fittest battery for competition.
We (I) put some tips on the AndyMark website: http://www.andymark.com/battery-tips-s/615.htm.
(Full disclosure of the probably obvious: I work at AndyMark.)
Unread 26-01-2017, 13:46
Gravity's Avatar
Gravity Gravity is offline
Invention is for chumps.
AKA: Alex Lederman
FRC #5940 (B.R.E.A.D.)
Rookie Year: 2015
Gravity is just really niceGravity is just really niceGravity is just really niceGravity is just really nice
We usually swap our batteries at the high 11v idling. Consider your battery empty at the low 11v.
Refer to this:
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Unread 26-01-2017, 13:53
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Most 12V AGM batteries don't like to be discharged below 10.5V (1.75 Volts per cell). If you repeatedly do this, you will experience a noticeable decrease in the battery's capacity over a short period of time. Put another way, if you abuse the battery by over discharging, the battery won't hold as much charge during the next cycle and you'll start noticing that the battery discharges faster.
Ed Sparks
MECH TECH FRC-3959
Unread 26-01-2017, 14:02
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
I mean we had some battery issues and it ran about 11V, but I would take it out around then. Keep the batteries charged, and at comp, swap batteries every match.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 26-01-2017, 14:48
I found the attached chart online.
Lead-Acid State of Charge vs Voltage, Richard Perez, Home Power #36, August/September 1993, Page 67
I can't vouch for the chart, but it says that if you let your at-rest battery voltage drop below 12 volts you've already discharged the battery by more than 75% (the State of Charge is less than 25%).
Last I checked, discharges no deeper than 50% (around 12.25 volts at rest) are recommended by FRC battery manufacturers.
Name:	Voltage vs SoS.png
Unread 26-01-2017, 19:27
DonRotolo's Avatar
Back to humble
FRC #0832
To emphasize: you really really need to swap out your battery for every match in competition.
Unread 26-01-2017, 20:37
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
We usually swap out the batteries when testing at around 12 to 12.1 volts maybe a little more.
