Go to Post Sometimes I think all the Game Hint does to us is make us terrible listeners. - Chris is me [more]
Unread 26-01-2017, 14:39
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
Re: ioctl Errors and Intermediate Vision sample not working
Originally Posted by Thad House View Post
For the first errors, which properties are you trying to set? There as some properties that will fail to be set if a certain other property is at a specific setting. For an example, if the exposure type is set to auto (which it is by default) any attempt to set the exposure manually will print that error. Knowing which camera, and which property you are trying to set will help debug that.
We're taking a look into the too many streams issue. For now, make sure all dashboards are closed, all internet browsers are closed, and restart the program. It seems like something is opening multiple stream connections.
Thanks!
We fixed the too many streams issue and we got into another issue, when we try to grab the frame, it returns 0 (meaning there's an issue). The issue is that there is no connection. How do we fix that? I mean, when we use the normal camera without processing it (in the smartdashboard just setting the property to USB Camera 0) it works and shows a consistent stream. When we switch the property to the one that's processing, it starts making these errors.
