Go to Post We're engineers. We fix problems, not complain about them. - plnyyanks [more]
Unread 26-01-2017, 16:48
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Motor Controllers Stop Working Below 50% Power in Labview
Rather than gear down our motors, we are trying to just drop the percentage of the power going through the motor controller in Labview. This works until we hit 50%(.5). Anything below 50.1% no longer works, as if no signal is going through to the motor controller. It is a spark motor controller if that helps.
Unread 26-01-2017, 16:58
Re: Motor Controllers Stop Working Below 50% Power in Labview
You are attempting to use a logic operator on floating point values.
The output of a logic operator is 1 or 0.
If you want to use a button to control the motor, here are some examples: http://www.team358.org/files/program...ControlofMotor
Or try one of these two variations for an axis control, just substitute a single motor for the Drive:
Unread 26-01-2017, 16:59
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Depending upon various factors, you need a certain amount of power to overcome the friction and inertia in your system. In prior years, that amount was about 25-30% power before the robot started moving.
50% seems a little high, but not unreasonable.
Unread 26-01-2017, 17:01
FRC #5005
So like this?(Asking since I'm using a button layout instead of joystick)
Edit: This still only works above 50%
Unread 26-01-2017, 17:19
Drop it by how much?
Unread 26-01-2017, 17:31
FRC #5005
We figured it out, I misread Mark's reply, his solution corrected the issue. I appreciate the help!
