Go to Post This is ChiefDelphi. There are threads on everything! - LauraN [more]
Unread 26-01-2017, 16:43
ebernerrd ebernerrd is offline
FRC #3236
ebernerrd is an unknown quantity at this point
SendableChoosers are causing me grief!
Hello! My name is Eric, and I am the lead programmer for team 3236. This is my first year, and so far, things are going good!
I am attempting to add radio buttons to my SmartDashboard so that I can choose the autonomous mode to run at a specific time. I am running it through a Command based system, as it seemed the easiest and most logical to my head.
In Eclipse, functions like "AddDefault" or "AddObject" do not work when written like this:
private:
		Teleop *TeleopControls;
		SendableChooser<Command *> *autonomouschooser;
		Command *autonomousCommand;
		virtual void RobotInit() override {
			autonomouschooser->AddDefault("Basic Auto", new AutoDefault());
			SmartDashboard::PutData("Chooser", autonomouschooser);
However, Eclipse recognizes these functions when the code is written as such:
private:
		SendableChooser *autonomouschooser;
In this case, I get the error "invalid use of template-name 'frc::SendableChooser' without an argument list".
I know that this is not because of an issue of "AutoDefault()" not existing, or anything along those lines.
If anyone has a possible solution or explanation, we'd greatly appreciate it!
Thank you!
-Eric
Unread 26-01-2017, 17:22
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: SendableChoosers are causing me grief!
This worked for us:
In Robot.h
private:
    frc::SendableChooser<frc::Command*> autoChooser;
    std::unique_ptr<frc::Command> selectedMode;
In Robot.cpp
Robot::RobotInit() {
    autoChooser.AddDefault("Do Nothing", new DoNothing(15));
    autoChooser.AddObject("Gear Align Center", new GearAlignCenter());
    SmartDashboard::PutData("Auto Chooser", &autoChooser);
Robot::AutonomousInit() {
    selectedMode.reset(autoChooser.GetSelected());
    if(selectedMode != nullptr) {
        selectedMode->Start();
Good luck with the season!
Best Wishes,
Drew
Unread 26-01-2017, 17:38
FRC #3236
Are you including any other libraries? I get some errors with that setup.
Thanks for the quick reply btw!
Unread 26-01-2017, 17:56
jreneew2's Avatar
AKA: Drew Williams
I'm including
#include "WPILib.h"
#include "RobotMap.h"
in Robot.h
and
#include "Robot.h"
in Robot.cpp
What is the error your getting?
Unread 27-01-2017, 14:24
FRC #3236
Originally Posted by jreneew2 View Post
I'm including
#include "WPILib.h"
in Robot.h
and
#include "Robot.h"
in Robot.cpp
I get the errors "Symbol SendableChooser could not be resolved" and "Type ::Command could not be resolved"
Unread 28-01-2017, 14:16
FRC #3236
I've actually gone and fixed these issues. When I write the code as you did, I get an error on SmartDashboard:utData("Auto modes", &autonomousChooser);
The error I have is:
invalid arguments
Candidates are:
void PutData(llvm::StringRef, frc::Sendable *)
void PutData(frc::NamedSendable *)
Unread 29-01-2017, 13:16
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
invalid arguments
Candidates are:
autonomousChoose was defined as a pointer already "SendableChooser<Command *> *autonomousChooser"
while the other team's example was NOT a pointer (no * before the variable name).
As such, PutData is looking for a pointer to be sent to it... so you should not preceed it with & but instead just give the name of the variable (the pointer). The other team needs the & in order to give an address (pointer) to PutData. I believe if you remove the & you'll be good there.
BTW, don't forget to 'new' any pointers before using them and 'delete' them at the end in some destructor like ~Robot()
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
