Re: USB Hub compatibility
Joysticks off a hub will work fine.
I'd recommend you get a small hub though, not a large one that would require supplemental power (then it's not so fine). There isn't anything you can do in LabVIEW with how the joysticks are plugged into the laptop. The joysticks are input by the Driver Station. |
The driver station will be reading the values based on the USB enumeration provided by the OS. Whether devices are inserted directly into one of the built in USB ports or a hub, they still need to be enumerated for any programs to work with them.
