Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 26-01-2017, 17:36
tiernan12992's Avatar
tiernan12992 tiernan12992 is offline
LabVIEW Coding Captain and Weirdo
AKA: Tiernan Pierce
FRC #4490 (TechRaiders)
Rookie Year: 2015
tiernan12992 is an unknown quantity at this point
USB Hub compatibility
So, we want to use a USB Splitter (Hub) on our driving laptop so that we can attach multiple controllers at once. The problem lies in two things: We don't have the hub yet and we don't really know how LabVIEW will react to us attempting to do something like that. Would LabVIEW respond to it well, or would we have to tinker with the code a bit more to have LabVIEW properly read the USB inputs and "mingle" with them?
Nothing makes an engineer more productive than the "Last Minute"
"I will only work for 50 rubles." - Quenten, one of our other coders (extraordinaire)
"I guess I'm the help deadline. Please call NEVER." - Codi, our other coder. (It is funneh joke because Codi iz coder)
Unread 26-01-2017, 18:10
Re: USB Hub compatibility
Joysticks off a hub will work fine.
I'd recommend you get a small hub though, not a large one that would require supplemental power (then it's not so fine).
There isn't anything you can do in LabVIEW with how the joysticks are plugged into the laptop. The joysticks are input by the Driver Station.
Unread 30-01-2017, 15:03
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
The driver station will be reading the values based on the USB enumeration provided by the OS. Whether devices are inserted directly into one of the built in USB ports or a hub, they still need to be enumerated for any programs to work with them.
