Re: Build Error: Image of roboRIO does not match plugin
Can you ping the roboRIO at roboRIO-6705-FRC.local using the cmd or terminal window?
Also, what OS are you running on your laptop. And are you connecting with an ethernet cable, wifi, or USB? If not USB, can you also try that? |
