Go to Post WATER GAME! Always a water game... - kendra21093 [more]
Unread 26-01-2017, 19:31
daoliverio daoliverio is offline
AKA: Dom
FRC #3484 (Short Curciut)
Team Role: CAD
Rookie Year: 2015
daoliverio is an unknown quantity at this point
Does Anyone Have a Urethane Welding Kit That We Could Use In Central Ohio?
Hello, I am on team 3484 out of Marysville, Ohio. I was wondering if anyone in the surrounding area has a urethane belt welding kit. If you have one that we could use I would greatly appreciate it!
Unread 26-01-2017, 19:33
Billfred's Avatar
Billfred Billfred is offline
Re: Does Anyone Have a Urethane Welding Kit That We Could Use In Central Ohio?
With a lighter and some care, you don't need a welding kit. Relevant reading, including the quoted bit:
https://www.chiefdelphi.com/forums/s...2&postcount=14
Really, the whole thread is worth your time: https://www.chiefdelphi.com/forums/s...hreadid=154267
Unread 26-01-2017, 19:48
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
there are plenty of alternatives, as Billfred mentioned you can use a lighter. I've had success personally with a heat gun in the past. Also, I've heard it helps if you cut them on an angle so you have more surface area on your weld.
Unread 26-01-2017, 19:56
Munchskull's Avatar
Munchskull Munchskull is online now
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Old soldering iron with a flatblade screwdriver for a tip works quite well.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 26-01-2017, 19:59
RoboChair's Avatar
AKA: Devin Castellucci
Here you go
https://www.chiefdelphi.com/forums/s...2&postcount=10
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 26-01-2017, 20:01
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Use a hot plate or an old pan on a stove and put it on the highest setting. Way easier to handle and it doesn't burn and char the urethane.
2016: FRC 865 Mentor
