Go to Post We need to all remember we are no better than our fellow man, no matter what job we all hold, what socio-economic status that's involved, or anything. Plain and simple, we're all fellow travelers on this pale blue dot called Earth. - trobots.com [more]
Unread 26-01-2017, 19:37
JoeyDaPanda's Avatar
JoeyDaPanda JoeyDaPanda is online now
AKA: Joey
FRC #6324 (The Blue Devils)
Rookie Year: 2017
JoeyDaPanda is an unknown quantity at this point
Question "Split Arcade" Drive with Xbox 360 Controller?
Hey there, rookie team 6324 here. We have a pretty big dilemma, and we're hoping you guys can help us out some. We are inexperienced in programming and need guidance.
Like the title says, we would like to have the left joystick of an Xbox 360 controller control throttle and the right thumbstick of the controller control turning. We have no clue how to achieve this. Currently the right trigger controls the left side wheels/motors, and the Y axis of the left thumbstick controls the right side.
Thanks!
Unread 26-01-2017, 19:59
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: "Split Arcade" Drive with Xbox 360 Controller?
robot_drive.arcadeDrive(xboxController.getY(Hand.kLeft), xboxController.getX(Hand.kRight));
This is assuming you've already made a RobotDrive object and an XboxController object, and that you are using Java.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 26-01-2017, 20:09
ben47955 ben47955 is offline
FRC #3996 (RIKITIK)
ben47955 is an unknown quantity at this point
I don't recommand to a team inexperienced in programming to try two type of drive. Focus on one and do well ( pratice your driver too).
But, if you really want to do this, I recommand to uses a toggle button for switch mode. It will be more simple to programming and robot will don't go in all ways.
Unread 26-01-2017, 21:02
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
I don't think that they wanted to do two types of drive, I think they wanted to figure out how to do the one they wanted. That being said, I don't think arcade drive is too complicated for any team to understand. It's one of the easier things to implement, especially since it's so well documented.
My FRC History:
Unread 26-01-2017, 21:03
Xavbro's Avatar
Xavbro Xavbro is offline
AKA: Xavier Eldridge
FRC #5829 (Awtybots)
Rookie Year: 2016
Xavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to behold
The type of drive you're asking for is very simple and we used it last year as a rookie team.
What you want to do is take one axis of the the controller and set it to straight and set the other axis of the controller to rotate.
***Java Code***
straight = (Robot.oi.xbox.getRawAxis(1));
rotate = (Robot.oi.xbox.getRawAxis(4));
We used an Xbox controller as well last year and found that the axis we wanted to use were 1 and 4. You'll have to double check with you team to see which ones you want to use.
After you've done that, you can tune the values for deadzones and such as needed. You would then use those values to apply to the drive motors as such:
leftMotor1.set((rotate + straight));
leftMotor2.set((rotate + straight));
rightMotor1.set(rotate - straight));
rightMotor2.set((rotate - straight));
(Of course if you're using more motors, you would add them. We only used 4.)
You might have to change the signs around to get the right direction and such but that's the code we used last year and it worked great.
If you have any questions, feel free to PM me. Hope this helps!
TigerBytes (FRC 4209): 2012-2013: Mentor
DiscoBots (FRC 2587): 2009: Member || 2010-2015: Mentor
Impact (FRC 2585): 2016-Present: Mentor
Awtybots (FRC 5829): 2015-Present: Mentor
Ri3D Team oRyon: 2014-Present: Programmer/Strategist
Unread 26-01-2017, 21:41
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Also, be mindful of the Xbox controller Axes. You can find them in the driver station USB panel.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 26-01-2017, 21:57
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Or you could just use WPILib's own RobotDrive->ArcadeDrive function.
Unread 28-01-2017, 08:54
AKA: Joey
Rookie Year: 2017
Yup, been telling the other guys working on this with my that since day one that the axes we want are 1 and 4 but they dont listen haha
Unread 28-01-2017, 09:02
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
We had the same issue of programming our linear strafing, and had a heck of a time too, but once we figured it out it was all good
Unread 28-01-2017, 09:37
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
The first thing we really need to know is what language are you guys using?
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 28-01-2017, 09:44
AKA: Joey
Rookie Year: 2017
Java definitely
