Go to Post The people that have posted in this thread are intelligent and I know that when they talk, I need to listen. - ATannahill [more]
Unread 27-01-2017, 05:23
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Need help solving the CAN mystery
BTW, here is an example for mecanum drive base. 8 lines total added to the standard Iterative robot code.
package org.usfirst.frc.team492.robot;
import com.ctre.CANTalon;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	final String defaultAuto = "Default";
	final String customAuto = "My Auto";
	String autoSelected;
	SendableChooser<String> chooser = new SendableChooser<>();
	Joystick leftStick = new Joystick(0);
	Joystick rightStick = new Joystick(1);
	CANTalon leftFrontWheel = new CANTalon(3);
	CANTalon rightFrontWheel = new CANTalon(4);
	CANTalon leftRearWheel = new CANTalon(5);
	CANTalon rightRearWheel = new CANTalon(6);
    RobotDrive myRobot = new RobotDrive(leftFrontWheel, leftRearWheel, rightFrontWheel, rightRearWheel);
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	@Override
	public void robotInit() {
		chooser.addDefault("Default Auto", defaultAuto);
		chooser.addObject("My Auto", customAuto);
		SmartDashboard.putData("Auto choices", chooser);
	 * This autonomous (along with the chooser code above) shows how to select
	 * between different autonomous modes using the dashboard. The sendable
	 * chooser code works with the Java SmartDashboard. If you prefer the
	 * LabVIEW Dashboard, remove all of the chooser code and uncomment the
	 * getString line to get the auto name from the text box below the Gyro
	 * You can add additional auto modes by adding additional comparisons to the
	 * switch structure below with additional strings. If using the
	 * SendableChooser make sure to add them to the chooser code above as well.
	@Override
	public void autonomousInit() {
		autoSelected = chooser.getSelected();
		// autoSelected = SmartDashboard.getString("Auto Selector",
		// defaultAuto);
		System.out.println("Auto selected: " + autoSelected);
	 * This function is called periodically during autonomous
	@Override
	public void autonomousPeriodic() {
		switch (autoSelected) {
		case customAuto:
			// Put custom auto code here
			break;
		case defaultAuto:
		default:
			// Put default auto code here
			break;
	 * This function is called periodically during operator control
	@Override
	public void teleopPeriodic() {
	    myRobot.mecanumDrive_Cartesian(leftStick.getX(), rightStick.getY(), rightStick.getTwist(), 0.0);
	 * This function is called periodically during test mode
	@Override
	public void testPeriodic() {
