Re: Team Update 6
"If a GEAR set corresponding to the next sequential unengaged ROTOR remains idle for more than ten (10) seconds, the rotation count resets to zero (0)."
Does this pretty much mean you have to go in order now? Can't see why you would go out of order anyways but I think this pretty much says go in order it you have to start over. |
Re: Team Update 6
Re: Team Update 6
Re: Team Update 6
Re: Team Update 6
Yes. It would be nice if people remembered to quote the rules when they make definitive statements about those rules.
Re: Team Update 6
It would also be nice if people read the rules thoroughly. Its not up to me to hand feed them. I gave them a reason to go look at the rules again, so they could learn.
#7
Re: Team Update 6
I'll admit: in my numerous re-readings of the 2017 manual, I missed the caption below a figure that explicitly states the rotors must be engaged in order, as did a few others in this thread.
And we're the 'good ones'. Aside from the occasional "do we have a weight requirement this year??" silliness, I'll refrain from ordering people to . |
#8
Re: Team Update 6
By not citing the actual rule, or in this case a caption in the rule book, it forces someone to do research into it. I don't need to tell someone to read the manual, I can give them a reason to by giving them information that they need to verify. Don't just hand your students the answer make them work for it and they'll remember it more. At least that's what all my teachers, that I would consider good, did for me. |
#9
Re: Team Update 6
So basically, you're saying that instead of just telling people where to find the relevant piece of information when you post it, you'd rather make them go back and read through a 130 page manual in the hopes that they'll spot that one line of text underneath a picture this time?
I make my students read the rule book. When they ask me questions I don't just give them the answer... but I do tell them roughly where to find the answer and help them interpret it. I don't just leave them to struggle through 130 pages without knowing if what they're looking for is even mentioned in there or a figment of someone's imagination. |
#10
Re: Team Update 6
Also, FIRST conveniently splits the 2017 Game and Season Manual into sections, as advertised on their website. You could safely bet that this rule in question would be in either Section 3: Arena, Section 4: Match Play, or Section 7: Game Rules. Last edited by Hallry : 27-01-2017 at 14:50. |
#11
Re: Team Update 6
And it's probably not in Sections 1,2,3,5,8,9, or 10. So, I mean, that rules out a lot of the manual to start with.
#12
Re: Team Update 6
Rotor = 57 mentions
Order = 34 mentions That's if you search the entire manual. Of course, something like this you'd think would be mentioned in the game rules, or maybe in match play, so you just open those one's up and search, don't find anything (Since it's talked about in the Arena), and assume what? That Eric is wrong? The point is, simply making a statement on here and forcing everyone else to go verify its reliability is making everyone look for a needle in a haystack, and it could be very easy for people to arrive at different conclusions based on the assumptions they make. If we really want to ensure reliable, easily verifiable discussion about the rules, references should actually be made to where we get our information. Trust me, in industry you don't just make statements about what's required for a product. You actually reference the requirement you're discussing, and when applicable even quote parts of it to ensure everyone is on the same page and agrees with whats been said. To do otherwise invites product errors. |
#13
Re: Team Update 6
Sure. It was correct in this case so we could have just left it at that. If it was incorrect, plenty of people would have corrected it. Such is CD.
#14
Re: Team Update 6
I'm so glad to know that I can just come on here and trust anything I read about the game so long as no one has come along to correct it yet.
#15
Re: Team Update 6
Has anyone Q&A'd to see if you can place gears out of order? Put 2 gears in set 2, then insert gear in 1, then rotate 2? Cause I read that to mean Rotor 2 won't start until Rotor 1 is turning. I don't think there's any way to enforce not placing gears out of order.
