Go to Post You will find we are more talkative in about 5 1/2 weeks. ;) - mrnoble [more]
Unread 23-01-2017, 00:17
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Can't update firmware of radio 2017
I am trying to use the FRC configuration utility (FRC_Radio_Configuration_17_2) to load the firmware onto the radio (OM5P-AC router). On multiple computers, I launch the program, select the Ethernet port, and hit the "Load Firmware" button. I then get the error:
Bridge firmware load field. Error finding NPF device name for adapter: Realtek PCIe FE Family Controller #2
Please reset the bridge and try again
I tried following the steps on this thread but alas no luck.
https://www.chiefdelphi.com/forums/s...d.php?t=142226
Does anyone have any ideas? This just shouldn't be this hard.
If I try to run the configure it does talk to the radio and tells me to update the firmware.
When I try to load the firmware I get an error on 3 different pcs.
We have never had issues in previous years with flashing the radio
Unread 23-01-2017, 09:23
FRC #4277
I also tried from command line
From there I get
AP51-Flash Hello
Verify image path: firmwareOM5PAC.bin: combined ext image <318054 bytes>
Sent from my Pixel using Tapatalk
Unread 23-01-2017, 09:30
AutomationFTW's Avatar
AutomationFTW AutomationFTW is offline
FRC #5829
Rookie Year: 2016
AutomationFTW can only hope to improve
Re: Can't update firmware of radio 2017
Could be a bug with the software. Our team just used the 2016 radio config utility to change the team number.
Unread 24-01-2017, 13:58
FRC #4277
From there I get
Still hoping someone can help. Can't get the radio firmware to update.
Unread 24-01-2017, 21:20
Thardro Thardro is offline
AKA: Ethan
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2015
Thardro has a spectacular aura aboutThardro has a spectacular aura about
We are stuck at the exact same point right now. Does anybody have any idea how to solve this?
Unread 24-01-2017, 21:24
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
If you disable all other network interfaces the firmware update will work.
You will know you have disabled all other network interfaces when there is only one interface selection when the Radio Configuration tool starts.
Unread 27-01-2017, 08:54
npetrie3 npetrie3 is offline
FRC #0135 (Penn Robotics)
Team Role: Electrical
npetrie3 is an unknown quantity at this point
I solved this issue by loading the firmware through a network switch.
Sent from my iPhone using Tapatalk
Unread 27-01-2017, 15:18
jafried jafried is offline
FRC #4137
jafried is an unknown quantity at this point
Team 4137 is having the same problem, have tried everything we can think of, rebooting the laptop that the configuration software is running on, removing and reinstalling configuration software, a different Ethernet cable etc.
Unread 27-01-2017, 15:33
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
I'm going with the simple route again, because a slight oversight caused us some issues and analyzing our hardware installation found the problem. PLus this is very easy to check and dismiss if I'm wrong. Here goes:
1. The power input needs to be connected to the 12V/2A output of the VRM. This is different from years past.
2. When connecting to the radio from a PC, the ethernet cable plugs into the port furthest away from the power input.
3. When connecting to the radio from the RoboRio, the ethernet cable plugs into the port adjacent to the power input.
I hope this helps. If it's software, that's not my realm.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 31-01-2017, 23:14
FRC #4137
Team 4137 was finally able to update the radio. This occurred a day after our 3 hours of frustration. Another mentor launched the Radio Configuration Tool and followed the instructions in the GUI. This is what we think was done the previous day, but this time with a different operator it worked.
No idea why the software and system behaved differently after 20 hours. So turn everything off overnight and try again. If the software was bullet proof then should not make a difference, it must get into a state where it hangs up. Doesn't make sense, but it is software.
