Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 27-01-2017, 15:22
wildcat5e's Avatar
wildcat5e wildcat5e is offline
FRC #6705
wildcat5e is an unknown quantity at this point
Re: Build Error: Image of roboRIO does not match plugin
Originally Posted by Joe Ross View Post
It would have been in the root of the eclipse project folder. However, I just realized that with the 2017.2.1 release, it is no longer used.
Ok. Then what should I try next?
