Go to Post Even if this is the Rumor Mill, there are behaviors that need to be adhered to. - meaubry [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 27-01-2017, 16:27
StrMNX StrMNX is offline
StrMNX is an unknown quantity at this point
CANTalon Python Help
So i'm trying to run a CANTalon at some RPM. i decided on PIDF control. i chose 1366 RPM because its the speed done in the Software Reference Manual. i've tried to convert the java code into python, but the shooter refuses to run. can anyone help me?
#!/usr/bin/env python3
import wpilib
import ctre
from networktables import NetworkTable
class MyRobot(wpilib.IterativeRobot):
    def robotInit(self):
        self.Shooter = ctre.CANTalon(1)
        self.Shooter.reverseOutput(False)
        self.Shooter.setFeedbackDevice(ctre.CANTalon.FeedbackDevice.CtreMagEncoder_Relative)
        self.Shooter.configNominalOutputVoltage(float(+0.0), float(-0.0))
        self.Shooter.configPeakOutputVoltage(float(+12.0), float(-12.0))
        self.Shooter.setProfile(0)
        self.Shooter.setF(0.1097)
        self.Shooter.setP(0)
        self.Shooter.setI(0)
        self.Shooter.setD(0)
        self.Shooter.changeControlMode(ctre.CANTalon.ControlMode.Speed)
        self.xb = wpilib.Joystick(2)
        self.sd = NetworkTable.getTable('SmartDashboard')
    def teleopPeriodic(self):
        self.sd.putNumber("Velocity", self.Shooter.getSpeed())
        if(self.xb.getRawButton(5)):
            self.Shooter.set(1366)
        else:
            self.Shooter.set(0)
if __name__ == "__main__":
    wpilib.run(MyRobot)
Unread 27-01-2017, 16:52
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: CANTalon Python Help
import wpilib
import ctre
        else:
            self.Shooter.set(0)
    wpilib.run(MyRobot)
Have you started with just a simple example, making sure that when you tell the motor to move it moves? Or did you start with this?
Unread 27-01-2017, 17:03
Yeah, it was tested and runs.
It works when I disable the speed change mode and run it on Normal .set(1) for percentage. But when I enable the speed change mode and set it to 1366 it won't run. Plus even with the .set(1), getSpeed() always returns 0.
Unread 27-01-2017, 17:15
virtuald's Avatar
RobotPy Guy
I know last year we used the speed mode and it worked.
One difference between your code and theirs is that they set P to something: https://github.com/CrossTheRoadElec/...Robot.java#L46
Unread 29-01-2017, 13:33
after running it with some P value it works
but the getSpeed() command simply returns 0.
any reason why that would be?
Unread 29-01-2017, 13:51
so i've tried both sending the getSpeed() value to smartdashboard and having them printed out in the console, and either one report 0 while the roborio dashboard reports a RPM value. any way i can resolve this?
Unread 29-01-2017, 15:21
virtuald's Avatar
RobotPy Guy
The RoboRIO dashboard? You mean in the self-test thing?
There's one more difference in their code and your code: You call reverseOutput, they call reverseSensor. Might make a difference?
Are you using the MagEncoder, or a different sensor?
Unfortunately, I don't own the hardware for this device, so I can't perform a test. I'm fairly certain getSpeed worked last year though. What does .get() return? Also, you might try seeing what getEncVelocity() returns.
Unread 29-01-2017, 15:28
virtuald's Avatar
RobotPy Guy
Also, have you upgraded to RobotPy 2017.0.6? There was a bug in prior versions that could cause weird issues because HAL was initialized twice.
Unread 29-01-2017, 16:09
i did not update to 2017.0.6
i will have to on the next meeting. and i'll play around with the code to see what else i can get. the RPM was in the self test function fine. i was using a TalonSRX wired up over the CANBus with a CTRE mag encoder hooked up to the Talon.
