Go to Post I am all for high school sports, but as Dean continually preaches, we sometimes are not putting enough emphases in the right places. - Bill Beatty [more]
Unread 27-01-2017, 16:53
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
Re: In your opinion, what's the best beginners tool to help teams with autonomous?
Originally Posted by rich2202 View Post
You will also need some switches to tell the robot which Autonomous Code to execute (which peg).
The cheapest is to use Smart Dashbord. However, I am not a fan of Smart Dashboard.
Next is to wire 3 switches to the DIO port of the RoboRio. The problem there is if the team forgets to set the switches (or sets them wrong) and you can't go back onto the field to fix it.
Our team uses a bank of switches via a joystick emulator. That plugs into the Driver Station. It will also work with the First provided Driver Station if yours isn't working for whatever reason.
https://smile.amazon.com/dp/B00UUROWWK
Well, we actually have autonomous selection on our dashboard. We used it last year for when we were or were not going under the low bar.
