Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 27-01-2017, 16:40
truell20 truell20 is offline
FRC #5806
truell20 is on a distinguished road
Using ntcore library c++
I am trying to use the ntcore library (github mirror link: https://github.com/wpilibsuite/ntcore) in order to communicate with the roborio from the jetson.
However, I'm not exactly sure how to compile and link the library. Could someone walk me through it?
Unread 27-01-2017, 16:46
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Using ntcore library c++
I was able to successfully compile it on a raspberry pi using the default command they give you in the readme. The Jetson is an ARM processor right?
Try running:
./gradlew :arm:build
To link the file you should be able to add to your build command
-I /path/to/lib/folder -l -ntcore
And of course at "ntcore.h" to your file
Unread 27-01-2017, 16:53
FRC #5806
I've done everything that you've suggested, jreneew2, except for the "-I /path/to/lib/folder." I am unsure what "path/to/lib/folder" refers to.
Unread 27-01-2017, 16:55
FRC #5806
"/usr/bin/ld: cannot find -lntcore collect2: error: ld returned 1 exit status"
Is the linker error that I'm currently getting.
Unread 27-01-2017, 17:37
jreneew2's Avatar
AKA: Drew Williams
So your include path is where ntcore was compiled. So probably something like /home/ntcore/bin/ntcore/lib.a
Unread 27-01-2017, 21:33
FRC #5806
Got it working. Thanks for the help.
Unread 27-01-2017, 21:34
jreneew2's Avatar
AKA: Drew Williams
No problem.
