Re: Team Update 6
The only reasonable case for placing gears out of order is a highly choreographed autonomous, as suggested by Siri, and by me in other threads. Possibly also disinformation relating to your total gear count as well. |
Re: Team Update 6
There *is* a penalty H14 for starting a rotor by any method besides turning the crank, which covers most of the rest of the 'creative gear scoring' Quote:
Re: Team Update 6
1. Fastest delivery to center peg, Pilot A lifts gear and hands to PB or sets near PB. 2. PB lifts and grabs gear with second fastest delivery. (You should know which this is.) 3. PB places both gears, finishing around 10-12s into match. And starts cranking for dear life. 4. At some point before (15 - 3 cranks) seconds, Pilot A has lifted last and slowest gear and slotted into Rotor 1. The idea is that Rotor 2 is the slowest part of the process. If you can start it first and feed it the fastest two gears, you probably have the best chance at starting both Rotors. Honestly, sans team this year I have nothing to ground my speculations, thus my musings about 3 gear autons and gear count deception potentially playing a role at very high levels. Siri, I'll admit that a completely literal reading of that section with new wording could mean that the 10 second timeout doesn't apply to any rotor past the next unengaged one. Which would make this possible, assuming no auton rotors: 1. Collect 5 gears + reserve. 2. Install on Rotor 4, spin thrice. 3. Remove, install on Rotor 3, spin thrice. 4. Install 2 leftover on Rotor 2, spin thrice. 5. Install next 6 gears on Rotor 4. 6. Install last, 12th gear on Rotor 1. 7. Rotors 2-4 engage instantly. Or within 3 PLC cycles. That just seems ridiculous and would make the 10 second timeout pointless. So I'm assuming the GDC is just poor at fully defining the Rotor behavior in prose. It'd be easier for me if they just posted that segment of the FMS code, but that's probably not going to happen. |
Re: Team Update 6
And Q82 (in part): "ROTORS only start if GEARS are installed in ROTOR order." In other words, you won't be able to start ROTOR 4 until all other ROTORS have been started, etc. As evidenced by the "in other words" of Q82, this is not a particularly tightly-worded section. (Requiring gears to be installed in rotor order is not in fact the same thing as starting rotors in order.) I suspect that HQ hasn't yet realized that this is of legitimate importance for some teams. As I read it now: 1) Rotors must be started in order. 2) A crank can be turned when a gear set is complete. 3) Rotation count resets when the next unengaged rotor has been idle for more than 10 seconds. I don't think that (3) explicitly means rotations within those 10 seconds while that rotor isn't the next in sequence don't count. My reading of the logical flow is ambiguous across any of the following Step 5s: Step 1 @ t=-3 Place Gear 1 in Rotor 2Then:
Trying to boil this down into a Q&A, I'm thinking: 1) It is understood that GEARS cannot be removed after a ROTOR is engaged. However, can a GEAR be removed after a ROTOR is rotated but before it is engaged? Does this differ if the rotating is less than a full revolution or is accidental or strategic (in the estimation of the referees)? 2) It is understood that ROTORs must be engaged in ROTOR order. Must GEARS be also installed (placed without rotating) in ROTOR order? [A82 seems to interpret the manual p23 this way, but the manual still says "installed" rather than engaged or rotated.] 3) If GEARS need not be installed in ROTOR order, can ROTOR N be rotated (for accumulation of the required 3 rotations) before ROTOR N-1 is engaged, assuming the third rotation and engagement of ROTOR N still occurs after N-1 is engaged? 4) If ROTORs need not accumulate rotations in ROTOR order, does the (10) second idle window from TU6 start with the first rotation or when that ROTOR becomes the next sequential unengaged ROTOR? Good point about deception regarding the number of gears you still need. My head was still stuck on autonomous. |
