Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 12-01-2017, 20:15
Zguptill Zguptill is offline
FRC #4944
Zguptill is an unknown quantity at this point
Cut down on lag to rio with usb cam?
We were having a lot of lag on our video stream through the roborio, is there a way to cut down on this lag?
Unread 12-01-2017, 21:25
sanghakchun sanghakchun is offline
AKA: Andy
FRC #0846 (The Funky Monkeys)
Rookie Year: 2015
sanghakchun is an unknown quantity at this point
Re: Cut down on lag to rio with usb cam?
I imagine it's either due to the amount of data you're sending or a connection issue.
I'd cut down on the resolution of the video stream and test for connection issues.
On the off-chance it's because of load on the roboRIO, maybe a coprocessor dedicated to video could be used?
Unread 17-01-2017, 19:09
SpicyCactus SpicyCactus is offline
FRC #3039
SpicyCactus can only hope to improve
We had this issue last year with using multiple cameras. If you are you using multiple cameras you could try switching in between the two with a button on your controller. If you are only using one camera try lowering you resolution or maybe you computer cannot handle the video stream.
Unread 18-01-2017, 13:14
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
What amount of lag are you looking at? We had <0.5 sec of lag last year. If you're using usb I don't think there's that much you can do...
Unread 28-01-2017, 12:11
Commandman7 Commandman7 is offline
FRC #4362 (Gems Robotics)
Commandman7 is an unknown quantity at this point
Last year, we had a linear relationship between camera bandwidth and latency, so turning down camera quality and framerates can help a lot. 10 FPS with lower latency is surprisingly usable compared to 30 FPS with higher latency. I'm not sure if you've done this / can do this, but if you are using a camera that supports H.264 encoding like the Logitech C920 series, you can do H.264 encoding on the camera itself, which takes a lot of the load and latency off the Roborio.
Unread 28-01-2017, 13:37
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Use an ip camera to go directly to the driver station
