Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 28-01-2017, 10:08
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
How to Code Linear Actuators
We are using linear actuators on our robot, but we can't find any information on how to code them. Is it the same as a limit switch, and how is it imported?
Thanks
Unread 28-01-2017, 12:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: How to Code Linear Actuators
I'm not a programmer.
The actuator itself is a motor (a legal one I hope!). So control it like a motor.
IF you decide to use limit switches or some other means of detecting its position, then when the 'switch closes' (or the 'Thingus Thinguses'), a digital input is used to detect that and possibly is used in the programming to do something (like shut the motor off).
Unread 28-01-2017, 14:36
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Are you talking about this thing? http://www.andymark.com/product-p/am-3515.htm
If so, this is programmed the same as a servo.
