Go to Post Good programmers always find a better way to do something, especially when it's not obvious where those improvements can be found. - Mr. Lim [more]
Unread 26-01-2017, 20:36
robot_rover robot_rover is offline
FRC #2225
robot_rover is an unknown quantity at this point
Get Control Mode from Talon SRX
I have been looking through the methods and the documentation and for the life of me I cannot find where you can get the current control mode of a talon SRX. Does anyone know how to obtain this?
Unread 26-01-2017, 20:41
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Get Control Mode from Talon SRX
CANTalon.getControlMode();
http://www.ctr-electronics.com/downl...tControlMode--
Unread 28-01-2017, 10:19
FRC #2225
Is there a labview equivalent of this?
Unread 28-01-2017, 10:55
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
There isn't actually a LabVIEW equivalent right now.
The control mode is part of the signals that get sent to the Talon SRX over CAN - the java/c++ calls are just returning the member variable of the software object, not a value returned from the Talon itself.
Right now the Get Status VI for Talon SRX only returns the cluster of signals that are being received from the CAN bus, not those being sent.
It's something that we might be able to add if it makes sense. What application are you trying to get the control mode for?
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
Unread 28-01-2017, 16:41
FRC #2225
Currently I was trying to get the control mode to see if it needed to be changed in teleop. When our bot is in auto it sets the mode to position. What I was trying to do was set the mode to speed in the teleop vi only if it wasn't already in Speed mode. Right now I have a workaround where it only runs the change mode code if the bot has been disabled since the last time the teleop vi was called.
Unread 28-01-2017, 16:43
You could just maintain a record of the last mode set in a Global variable.
Then check it when you go to set a mode to see if it's different.
Unread 28-01-2017, 16:48
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
If you always want speed mode in teleop, you could just set it to speed regardless of mode. There's no issue with redundant mode change calls.
Edit: what Mark said above would also work for the way you're trying to go about it.
Edit again: Additionally, if you're only changing out of speed mode in auto, another solution would be to set the talons to speed mode at the very end of the routine.
Unread 28-01-2017, 16:50
FRC #2225
I suppose since it's a value the robotic sends it will not matter how often it is change. That's nice and easy. Thanks all o/
