Go to Post As much as you may want the ChiefDelphi community to see your argument, we may not want to see yours. - Amanda Morrison [more]
Unread 28-01-2017, 16:20
generaldgibson generaldgibson is offline
generaldgibson
AKA: Daniel Gibson
FRC #3397 (FRC Robolions)
Rookie Year: 2015
generaldgibson is an unknown quantity at this point
Camera Code
I've been trying to use the CameraServer class to get the camera to send feed to the SmartDashboard, but I haven't managed to get it to work. I'm using a Microsoft LifeCam HD-3000 which I know works; I'm programming in Java with the WPILib plugin up to date. Any help on how to use the CameraServer would be appreciated. Thanks!
Unread 28-01-2017, 18:13
MuskieProgramme MuskieProgramme is offline
FRC #6420
MuskieProgramme is an unknown quantity at this point
Re: Camera Code
public void robotInit(){
  CameraServer.getInstance().startAutomaticCapture( 0 );
Unread 28-01-2017, 18:24
ProffessorGordo ProffessorGordo is offline
FRC #2883
ProffessorGordo is an unknown quantity at this point
Smile Re: Camera Code
Originally Posted by MuskieProgramme View Post
This should also work with C++.
if you ever want to do multiple, try this thread:
https://www.chiefdelphi.com/forums/s...d.php?t=154213
Unread 28-01-2017, 19:24
AutomationFTW's Avatar
AutomationFTW AutomationFTW is offline
FRC #5829
Rookie Year: 2016
AutomationFTW can only hope to improve
Re: Camera Code
try:
//All under robot.java
import edu.wpi.first.wpilibj.CameraServer;
//under robotInit
camera = CameraServer.getInstance().startAutomaticCapture()
