Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Unread 25-01-2017, 18:17
Tank1357 Tank1357 is offline
FRC #3640
Tank1357 is an unknown quantity at this point
If a. Run motor
Hello,
I am fairly new to FRC and I am supposed to be the programmer for my team. I am currently working on a program that will run a motor controlled by PWM for two seconds, if the button A on a Xbox controller is pressed. I have read articles and forums that explain bits and pieces on how to do it, but I am having problems putting those pieces together into a working program. I learn best by example, so if somebody could give me an example of the code for this program, it would be greatly appreciated.
Unread 25-01-2017, 19:42
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: If a. Run motor
I would watch these videos about RobotBuilder. Pay close attention to the Claw subsystem.
https://www.youtube.com/watch?v=k7Pa...ObeKzp&index=1
Unread 27-01-2017, 13:50
WilliamFRC4065's Avatar
WilliamFRC4065 WilliamFRC4065 is offline
FRC #4065 (The Nerds of Prey)
Rookie Year: 2016
WilliamFRC4065 is an unknown quantity at this point
Talking Re: If a. Run motor
Coming from a person who has scoured screen steps for the exact same thing...
(These are just examples)
//First declare the joystick somewhere as a pointer
frc::Joystick* controller;
Then,
//Make a bool and assign it to the controllers button in Telop
bool a;
//Pretend 1 is A for now
a = controller->GetRawButton(1);
if(a){
motor1->Set(0.5);
Now I just gave you examples. You need to put them in the right places though:
//The bool goes into the robot init
//The joystick definition goes in the private section of the robot class
//And the code to execute it goes in telopPeriodic
Unread 27-01-2017, 13:51
Rookie Year: 2016
Re: If a. Run motor
Then,
bool a;
if(a){
motor1->Set(0.5);
ONLY IF YOU ARE USING A ITERITIVE!!!
Unread 28-01-2017, 18:27
FRC #3640
Re: If a. Run motor
Thank you so much, this was very helpful.
