Go to Post Would FIRST be as amazing if not for CD? I mean it would still be this amazing place for students and mentors to be but the explosion of innovation and gathering of people together across communities has to have been greatly effected by CD. - dodar [more]
Unread 28-01-2017, 13:53
Kevin Zhang Kevin Zhang is offline
FRC #3501
Kevin Zhang is an unknown quantity at this point
GRIP and Raspberry PI
Hello,
I am currently working with GRIP and the Raspberry PI. I am a bit unsure of the connection between the 3 components.
I am planning on plugging a usb camera in the Raspberry PI, run the vision processing there using GRIP and then sending the values onto NetworkTables with a certain name to get onto the roborio to process for drive adjustment.
If I am using java, do I need wpilib java package with the Network Tables on the Raspberry PI? Where do I add the function for adding the NetworksTable table and what is this function?(is it the same function as the one we use in normal java code that is deployed to the roborio)
Thanks
Unread 28-01-2017, 19:33
AutomationFTW's Avatar
AutomationFTW AutomationFTW is offline
FRC #5829
Rookie Year: 2016
AutomationFTW can only hope to improve
Re: GRIP and Raspberry PI
What version of the Rasperry Pi do you have?
For RPi 2:
https://github.com/WPIRoboticsProjec...Raspberry-Pi-2
As for NetworkTables I think this should help:
http://wpilib.screenstepslive.com/s/...-networktables
