Go to Post I think we need to take away your hammer privileges. - Katy [more]
Unread 28-01-2017, 14:58
Jdkmotorhead's Avatar
Jdkmotorhead Jdkmotorhead is offline
FRC #5102 (The Underbots)
Rookie Year: 2015
Jdkmotorhead is an unknown quantity at this point
GRIP Read CameraServer Output
Hello, my team and I have been experimenting with the new 2017 CameraServer, and I was wondering if it is possible to access the dashboard stream from GRIP on a coprocessor connected to the network, now that the class uses an mjpeg stream? And if so, how? We have tried using the roboRio IP address without success; should we use a different IP, or is there a specific port that the camera's on?
"It's not a software issue."
Unread 28-01-2017, 18:32
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: GRIP Read CameraServer Output
Add IP camera, set URL to
roborio-TEAM-frc.local:1185/?action=stream
WPILib
GRIP, RobotBuilder
Unread 29-01-2017, 00:34
Rookie Year: 2015
Thanks! I'll try this next time I'm at the build room.
Unread 29-01-2017, 15:46
Rookie Year: 2015
Is it possible to send multiple camera streams from the roborio to GRIP simultaneously?
Unread 29-01-2017, 16:04
FRC #2084
Yes. Each call to startAutomaticCapture() will host a stream on the next port. The first one is on 1185, the second is 1186, third is 1187, and so on
Edit: I misremembered. Ports start at 1181, not 1185
WPILib
GRIP, RobotBuilder
Unread 29-01-2017, 19:29
Rookie Year: 2015
OK, Thanks!
