Go to Post Sleep? What is sleep? - artdutra04 [more]
Unread 29-01-2017, 10:38
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Eclipse help needed
Just getting strated following the WPILIP example...
We create a new project, Command Based and select the Robot Java Project as stated in the WPILIB...
When we try to create our first subsystem, I cannot locate the folder commands and subsystems... thereofre i cant get to the "new, subsystems or command....
We have the plugins installed and the proper JRE...
Guess i am missing something very silly and cant figure it out....
Unread 29-01-2017, 10:57
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Re: Eclipse help needed
Does File -> New -> Other... -> WPILib Robot Java Development have the subsystem/command options you're looking for?
The command and subsystem folders should be in the package explorer view under the name of your project -> src
Unread 29-01-2017, 12:50
Coach Seb's Avatar
Rookie Year: 2015
yes! thank you.
This is what my package explorer look like....
https://goo.gl/photos/ezYrRn6KUNT4JpVC6
i was not seeing the folder as they have in the tutorial... and since i am new with java and s=eclipse, it made me a little nervous.
Is there a way i can have these "others" option available when i select "new" instead?
Unread 29-01-2017, 14:25
forbes's Avatar
Software developer
AKA: Evan Forbes
You can go to Window -> Customize perspective... -> Shortcuts and select the ones you want to show up in the "New" submenu
