Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Unread 29-01-2017, 14:19
mGeorgeXYZ mGeorgeXYZ is offline
FRC #3397
mGeorgeXYZ is an unknown quantity at this point
Re: USB Camera Not Detected!
We are having the same problem (I think). I can see that the USB camera is working by examining the variables in the network table, also the image can be viewed with the "Smart Dashboard" by adding the widget. However from the default dashboard, I select the camera, and no image is displayed. The new control that has sliders for frame rate and compression has no effect. Are you saying that we rebuild the dashboard vi from labview, with a simple fix to one of the vis? Thanks.
Unread 29-01-2017, 14:41
nhalstead's Avatar
nhalstead nhalstead is offline
Noah H
FRC #5420 (Velocity)
nhalstead is an unknown quantity at this point
For me I was using an older robot from 2015 (Recycle Rush). FIRST has a new VI you have to use to make the camera feed goto the dashboard. In LabVIEW it is in the Robot Main.vi and you have to add the "Send 2 PC" Camera WPI vi.
Then you just need to connect the error line to it.
It seemed to have worked for me.
If you can not find the Object like I couldn't you can Create a New Robot Project then just Copy the Object from there and past it into your other project.
Good Luck. Hope it helps!
