Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
  #31   Spotlight this post!
Unread 29-01-2017, 14:51
Skyehawk's Avatar
Skyehawk Skyehawk is online now
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Intake Conveyor Ideal Speed
Originally Posted by ImMoMo View Post
Good discussion,
I'm thinking that we're going to use a 10:1 Versa Planetary reduction with a 775 for our intake and elevator.
With 31 RPS, I think we'll be intaking fuel pretty fast.
Although I'm worried that we wont have enough power to lift palls up our elevator. Any experience with this?
Also, if we have wheels on our roller (1/2 shaft) how would I incorporate them into my calculations? Specifically on JVN.
Personally I would have your intake and elevator on seperate motors. It's probally best if you are capable of controlling them seperatly if a game piece jam happens. This should also take some of the stress off of that 775pro (even thogh it is overkill anyway)
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
  #32   Spotlight this post!
Unread 29-01-2017, 15:38
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Good discussion,
You can guess how much force your intake will experience from lifting game pieces, compression, wheels on the shaft providing inertia, and a variety of other factors, but the best way to see if it will work is to prototype. If you haven't built a model of your intake with approx. the gear ratio you want, I would suggest doing that. If you don't have access to the right motor and gearbox, at least try with a hand drill on drill speed to make sure that you don't need too much torque.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
  #33   Spotlight this post!
Unread 29-01-2017, 15:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Good discussion,
Take your shaft speed (rev/s), multiply by wheel circumferential travel (ft/rev), and you'll get the collector 'surface speed' in ft/s. Compare to robot maximum speed, ...? Profit!
  #34   Spotlight this post!
Unread 29-01-2017, 20:07
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
That makes sense, although I'm still unclear on what you mean by circumferential travel.
Thanks.
  #35   Spotlight this post!
Unread 29-01-2017, 20:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Thanks.
The circumference.
  #36   Spotlight this post!
Unread 29-01-2017, 21:24
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Strong Necro is strong.
Aside from that, the 15:1 versaplanetary that we are using with 1 1/4" rollers and an orange poly belt is now throwing them over the back of our bot.
  #37   Spotlight this post!
Unread 30-01-2017, 10:10
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
775pro on a VP 10:1 seems to devour fuel at a good rate for us.
Using Banebots blue wheels (2-3/8"), and yellow urethane round belt.
Test: https://drive.google.com/file/d/0B7z...ew?usp=sharing
[Note: I'm the mentor putting my forearm in harms way]
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
