Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 29-01-2017, 14:09
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
A Note For Those Using NetworkTables
Hey everybody!
My team discovered today that the reason why our vision code on the Raspberry Pi wasn't working despite our NetworkTables being set up correctly as far as we could tell. The problem was that we were trying to view the video stream in Internet Explorer, which for some reason couldn't handle a video stream. We used Chrome instead and were able to see a video feed!
We had assumed that we should use Internet Explorer to see the stream since screenstepslive said to use it when connecting to the roboRIO to do stuff like imaging Talons. Turns out, Internet Explorer isn't always the solution!
Moral of the story: if your vision code should be sending a stream to the driver's station but you're not getting one, try using Chrome.
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
Unread 29-01-2017, 15:11
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: A Note For Those Using NetworkTables
How is this relative to NetworkTables? Network tables allows you to send key/value pairs between different nodes on the network. Video streams are completely separate from and don't rely on NetworkTables.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 29-01-2017, 15:12
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
This is CameraServer related, not NetworkTables. Internet Explorer does not have the ability to view MJPEG streams. Use a different browser (Firefox, Chrome, and Edge all work). We'll get this added to the documentation. Note this also isn't an issue if you use a different application (e.g. SmartDashboard) to view the stream.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 29-01-2017, 15:23
Autonomous Queen
My team had thought that we were having issues with our NetworkTables, and we actually weren't because we were using the wrong browser. I posted this with the title being about NetworkTables so if another team was having the same issues as us and searching CD they would be more likely to find this thread.
Unread 29-01-2017, 15:28
Autonomous Queen
We actually can't use SmartDashboard to view our stream, that's what we're working on debugging now.
Unread 01-02-2017, 16:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
And the reason that you need to use Internet Explorer with the RoboRio is because Chrome does not support Microsoft Silverlight. In fact, Microsoft has announced they aren't going to support it anymore either in the future.
