Go to Post ... boundless mentory goodness ... - pfreivald [more]
Unread 29-01-2017, 15:45
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: 2 gear autonomous
To kinda elaborate further on Cal's response, no not really. You cannot legally enter your opponent's LAUNCHPAD to get to your retrieval zone, so you can't get to your stock of gears. Even if you could, you cannot go past the white line in the loading lane to load a gear, so that's out. You can't get one out of your own alliance station's loading station because of the same reason. The only way you could do it if both alliance decided to go full scale hard core Cooperition. One alliance gives up their pre loaded gear, puts on a specific spot inside the neutral zone, then the other alliance grabs it after putting a gear into the airship and then putting that second gear into your airship.
In short, no. No team is going to put the time to put this autonomous mode to either never use, or just use to benefit the other alliance only. Bragging points only.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
