Go to Post If they ask you to stop - you stop. - techhelpbb [more]
Unread 29-01-2017, 14:43
saintblaze4639's Avatar
saintblaze4639 saintblaze4639 is offline
FRC #4639 (The RoboSpartans)
Team Role: Driver
Rookie Year: 2016
saintblaze4639 is an unknown quantity at this point
2 gear autonomous
is there any way to place multiple gears from one robot in autonomous?
Unread 29-01-2017, 14:50
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: 2 gear autonomous
If you can convince an alliance partner to give up theirs and somehow support it fully and drop it in a reliable manner, go for it.
Academic Student (Forever)
Unread 29-01-2017, 15:45
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
To kinda elaborate further on Cal's response, no not really. You cannot legally enter your opponent's LAUNCHPAD to get to your retrieval zone, so you can't get to your stock of gears. Even if you could, you cannot go past the white line in the loading lane to load a gear, so that's out. You can't get one out of your own alliance station's loading station because of the same reason. The only way you could do it if both alliance decided to go full scale hard core Cooperition. One alliance gives up their pre loaded gear, puts on a specific spot inside the neutral zone, then the other alliance grabs it after putting a gear into the airship and then putting that second gear into your airship.
In short, no. No team is going to put the time to put this autonomous mode to either never use, or just use to benefit the other alliance only. Bragging points only.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 29-01-2017, 16:09
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
That's creative, and I don't think I've heard that idea from anyone before, and I certainly hadn't thought of it myself. I don't think that's how one robot would end up doing a two (or three) GEAR auto, though. There are several threads already that discuss some possibilities that are more likely.
It won't happen often, but it will happen that a team gets two GEARS in auto.
http://www.angelbotics.com
Remember why you're doing this.
Unread 29-01-2017, 16:10
mrnoble's Avatar
teacher/coach
That's more like what will happen
Unread 29-01-2017, 16:44
euhlmann's Avatar
euhlmann euhlmann is online now
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
You just need the partner to have the gear half on top of their bot, so that when auto starts it slides off. You'd need a floor gear pickup of course, but after that, finding the gear on the floor shouldn't be too hard considering that it's bright yellow
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 29-01-2017, 18:29
John.Benz's Avatar
John.Benz John.Benz is offline
FRC #0093 (N.E.W. Apple Corp Robotics)
John.Benz is an unknown quantity at this point
There is some use and that is playoffs. Lets say one robots places their gear. The other robot can do a two gear auto while the other robot is a high goal shooter. The high goal shooter can immediately drive to the hoppers, dump it into their robot and start shooting in autonomous. This will easily get you alliance over 40 kPa in auto for scoring the fuel and 20 more (or a RP in quals) for the fuel. Meanwhile the two gear auto robot has placed their preload and placed the shooter teams preload. That is 120 points from gears, and another 60 from fuel for an 180 point autonomous. Keep in mind the fourth rotor is worth 140 points in playoffs.
Unread 29-01-2017, 18:32
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
A 2 gear auto is only worth the effort if all 3 gears get placed on a peg and start roters in auto. Otherwise you haven't accomplished anything worthy of the complexity required for this auto.
I'm not saying it won't happen, because teams are clearly looking at it, but I don't see the benefit of it.
2012-Present Wave Robotics Team 2826
Unread 29-01-2017, 19:47
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Another way to get a GEAR from an alliance partner is to recreate the LIFT on your robot. Lots of robots are relying on the Human Player to lift the GEAR out of their robot already. So a horizontal rod on a vertical actuator might be easier to work with than expecting the alliance partner to drop the GEAR and pick it up then score it. But either way, I still consider placing a GEAR and scoring FUEL to be more beneficial than scoring two GEARs.
Unread 29-01-2017, 19:52
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
If your partner can place a gear onto a lift, they should just do it on an actual lift. If they can't place a gear onto a lift, then this strategy isn't helpful. If they're 50-50, this is only good if it's somehow easier to place onto your robot than the actual lift, and even then, was it worth all that extra effort?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 29-01-2017, 20:25
mrnoble's Avatar
teacher/coach
Getting three GEARS up to the pilots in auto means that only 3 are now needed to get the third ROTOR spinning, and "only" nine to complete all four. It might be more about saving time than scoring auto points. Maybe.
Unread 29-01-2017, 20:34
Registered Muser
Nope. Not at all. As I said, scoring a GEAR and FUEL is far more helpful. But if for some reason a team decides that scoring two GEARs is important, there's more than one way to do it.
Unread 29-01-2017, 20:51
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Is it possible? Perhaps. Is it really worth it? Probably not. It's much easier to cheesecake a gear holder onto a pushbot rather than come up with a complex auto that drops off a gear, finds and picks up another one, and then navigates back to the peg within about 10 sec (it takes a bit of time to get the gear on and start up the rotor). It's much easier on the human players and the robots if three robots are placing one gear each.
Unread 29-01-2017, 21:16
mrnoble's Avatar
teacher/coach
Cheesecaking a box is easier than cheesecaking a camera and autonomous code to place the gear on a peg. I'd say, cheesecake a "drive forward" bit of auto code for teams that can't do that, and ask them to place their gear precariously on their bumper.
Unread 29-01-2017, 21:29
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 will become famous soon enougharichman1257 will become famous soon enough
G27. One-GEAR limit. ROBOTS may not control more than one GEAR at a time.
Violation: FOUL. If strategic, TECH FOUL and YELLOW CARD.
I mayou just be reading the thread here wrong but it seems add if this rule has been over looked.
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
