Go to Post We want your $0.02!!!! (and for that matter, if anyone can loan me $1.49 for a few donuts....) - dlavery [more]
Unread 29-01-2017, 23:23
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Originally Posted by SamCarlberg View Post
That example is 4 years old. All you have to do on the pi:
NetworkTable.setClientMode();
NetworkTable.setTeamNumber(1512);
ITable visionTable = NetworkTable.getTable("vision");
That'll set up the pi and a table specifically for vision. If you launch OutlineViewer from Eclipse (WPILib > Launch OutlineViewer), you'll be able to see the values update in realtime.
Then to publish the results from the vision processing
visionTable.putBoolean("Have target", haveTarget);
visionTable.putNumber("Angle to target", angleToTarget);
In your robot program, you'd also declare a table for vision just like we did on the pi. To read the values the pi is publishing, use the corresponding 'get' methods
haveTarget = visionTable.getBoolean("Have target", false); // default to false
targetAngle = visionTable.getNumber("Angle to target", 0); // default to 0
Does anyone know of a vision processing tutorial?
Sent from my Pixel using Tapatalk
