Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 16-01-2017, 11:23
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Connection Issues
Hello,
Today we were trying to connect to our robot. We used last year's robot (last year's roboRIO, etc.). Prior to doing this, we re-imaged the roboRIO (we confirmed the new image was 2017v8), updated firmware on two radios (one from last year, one new one), and configured the radios to a 2.4 GHz access point. However, when we tried to connect to the robot, the wifi choices listed our robot, and allowed us to connect. However, the Driver Station did not see comms from the robot, and when we tried to visit roborio-4557-FRC.local through a browser, it said that the configuration page was unavailable*.
We also noticed that the wifi light on the radio (both were tried) turned yellow instead of the usual green. If you're able to help us out, that would be great!
*I read somewhere that they took the configuration page away. Can someone confirm this one way or the other?
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 16-01-2017, 12:09
Re: Connection Issues
A yellow light on the radio is good when you're connected.
If by configuration page you mean the radio's web server where we used to be able to check and adjust it's settings-that's gone. The FRC radio firmware doesn't include a web server.
I'd hook up a USB cable between your PC and roboRIO (while keeping the roboRIO connected to the radio) to see what Ethernet IP it got assigned and if it's compatible with the IP your PC got assigned.
Unread 16-01-2017, 14:09
Roboter
Rookie Year: 2015
I'll try it out tonight and let you know.
Unread 16-01-2017, 15:18
Roboter
Rookie Year: 2015
Also, a follow-up question:
If the config page is gone, how do we set device numbers for Talon SRX's on the CAN network?
Unread 16-01-2017, 16:16
The roboRIO configuration page is still there.
Hookup your USB cable and browse to 172.22.11.2
Unread 16-01-2017, 19:50
Roboter
Rookie Year: 2015
Thanks for the help. We were able to connect today. One last question (hopefully )*, we were able to connect to the new radio by ethernet today (as well as by wireless to the old radio), but we weren't able to connect wirelessly to the new radio.
Couldn't decide so here's an xkcd comic on the matter https://xkcd.com/541/
Unread 16-01-2017, 21:51
Did the new radio show up at all in the wireless list on the PC?
It's possible it uses the team number followed by an underscore (4557_ ) for instance-depends on if you put anything in the Robot Name field.
What did the new radio wifi status light show?
I assume only one radio was powered at the same time and both were set for 2.4GHz operation.
Unread 16-01-2017, 22:05
Roboter
Rookie Year: 2015
1. No, it did not show up in the list.
2. The wifi status light was not on.
The radio was set for 2.4 GHz and operated alone. On set-up, nothing was entered into the robot name field.
Unread 16-01-2017, 22:17
If the wifi light was not on, then run the radio through the FRC Radio Config Utility again.
You can also try cycling the radio power.
For whatever reason, it failed to startup wifi.
If it starts correctly the wifi light should be red, before the PC connects, and yellow after it connects.
Unread 16-01-2017, 22:24
Roboter
Rookie Year: 2015
I'll try it tomorrow and let you know how it goes. Thanks!
Unread 24-01-2017, 17:06
shieldrobotics shieldrobotics is offline
FRC #5785
shieldrobotics is an unknown quantity at this point
Hello,
Today we were trying to connect to our radio.
Prior to doing this, we re-imaged the roboRIO, updated firmware on the radio, and configured the radios to a 2.4 GHz access point. However, when we tried to connect to the robot, the wifi choices did not list our robot.
We restarted our computer and the robot multiple times but nothing helped.
Any advice? All tips or ideas are welcome!
Thanks in advance
Unread 30-01-2017, 00:27
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
Originally Posted by Hitchhiker 42 View Post
Hello,
We are having a similar issue. We can connect wirelessly using the DS and the webdashboard to the RoboRIO, but cannot load programs using Eclipse with Java. This worked fine until we updated to the 2017 FRC Update, 2017 Radio Firmware, 2017 Eclipse FRC Plugins, and the 2017 RoboRIO image. The only way we have been able to program the RoboRIO since then is via USB.
The error that comes up prior to BUILD FAILED is a "connection refused" when attempting the connection to port 22 (ssh) on the RoboRIO. We tried turning off the firewall on the laptop, tried other laptops, tried a different RoboRIO, a different radio, re-imaged the RoboRIO again, re-flashed the radio again. We initially loaded firmware on the radios with the "firewall" box checked, so we ran through the process again without it checked (which is the default). That also didn't make any difference. We also couldn't ssh into the roborio from a Linux machine on the robot network, so it doesn't appear to be an issue on the laptop side of things.
Has anyone else experienced these sorts of problems? Again, the robot can be operated wirelessly, and the webdashboard is working fine when connected wirelessly.
Thanks in advance for any suggestions.
Unread 30-01-2017, 09:33
A couple of things to try on the ssh and other connections that aren't working-
(1) On one of the connections that won't work, try connecting to:
roboRIO-2220-frc.frc-robot.local
(2) use IE or Firefox to connect to the roboRIO over USB and see what Ethernet IP the roboRIO was assigned (on the front webpage). Try connecting directly to that IP address.
(3) You can try hardcoding the roboRIO IP address to 10.22.20.2, however you must always have the roboRIO and PC connected through the radio for it to work.
Unread 30-01-2017, 09:53
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Hello,
Our new KOP 12V OpenMesh radio still isn't starting wifi, the wifi light doesn't come on and the network doesn't show up in the list. We realized we needed this fixed before competition, so it has become urgent. We tried reconfiguring- still no wifi. We reloaded firmware and reconfigured- still no wifi. At this point we do not know our other options. Any help is much appreciated.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 30-01-2017, 10:17
If the radio wifi light doesn't come on it can't work.
Is the radio powered by one of the VRM 12v/2a connections? The 12v/500ma connection doesn't supply enough power for the wifi to reliably operate.
Are you reinstalling the firmware & reconfiguring the radio from different PC's, in case it's a PC hiccup?
Do you have last year's radio to try?
Is the roboRIO Ethernet cable plugged into the radio port closest to the power connector?
