Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 30-01-2017, 11:46
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Encoder Help
Originally Posted by Team5709 View Post
Encoder: Encoder Kit AMT103-V (fc17-033)
they will be wired into the RoboRio. They are mounted on the out put shaft of the drive gear boxes. one on the left and one on the right. There is no gear ratio because its on the out put shaft and not on the motor it self. We are gonna be using arcade drive. The wheels are the 6 inch wheels (http://www.andymark.com/HiGrip-Wheel...?1=1&CartID=0). The motor controllers we are using are the 2015 Talon KOP controllers and those are using PWM.
Check out the screensteps reference: http://wpilib.screenstepslive.com/s/...or-other-shaft
And check out how to configure your encoder's pulses per revolution on the datasheet, page 4 http://www.cui.com/product/resource/amt10.pdf
Keep "maximum rpm" in mind when choosing a value. Choose the highest number of ticks that fits your intended rpm for the best accuracy.
Then you can get distance like this
Encoder enc = // create encoder as per screensteps
int ticksPerRev = // what you set them to
double diameter = 6.0; // inches
double distancePerRev = diameter * Math.PI;
enc.setDistancePerPulse(distancePerRev / ticksPerRev);
// later
double currentDistance = enc.getDistance(); // in inches
Edit: I'm unfamiliar with the 2015 KOP, but if those are Talon SRX controllers, you're a lot better off using CAN than PWM, because you can connect the encoders directly to Talons for high rate PID control.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
