Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Unread 30-01-2017, 12:24
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: Connection Issues
Originally Posted by Mark McLeod View Post
If the radio wifi light doesn't come on it can't work.
Is the radio powered by one of the VRM 12v/2a connections? The 12v/500ma connection doesn't supply enough power for the wifi to reliably operate.
Are you reinstalling the firmware & reconfiguring the radio from different PC's, in case it's a PC hiccup?
Do you have last year's radio to try?
It is connected to the proper power connections. Last year's radio still works I believe. We have not tried installing it from different PCs. Is last year's radio legal to use this year?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 30-01-2017, 12:35
Yes, last year's radio is legal.
Originally Posted by R62
One (1) OpenMesh Wireless Bridge (P/N: OM5P-AN or OM5P-AC)
Unread 30-01-2017, 14:03
FRC #3007
Rookie Year: 2015
Thanks
Team 3007: 2017
Unread 31-01-2017, 10:35
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
A couple of things to try on the ssh and other connections that aren't working-
(1) On one of the connections that won't work, try connecting to:
roboRIO-2220-frc.frc-robot.local
(2) use IE or Firefox to connect to the roboRIO over USB and see what Ethernet IP the roboRIO was assigned (on the front webpage). Try connecting directly to that IP address.
(3) You can try hardcoding the roboRIO IP address to 10.22.20.2, however you must always have the roboRIO and PC connected through the radio for it to work.
Mark, thanks for the tips. However, we do not have issues connectly wirelessly when using either the Driver Station or the WebDashboard -- both work fine. It is only when trying to download a new RoboRIO program from the Eclipse environment which uses SSH on port 22 under the hood.
We are going to try different firmware tonight to see if it makes any different (2016, and 2017 kickoff -- we are currently using the latest firmware from 1/8/2017 I think).
Unread 05-02-2017, 20:21
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
We have narrowed down this problem to the FRC Radio Configuration Utility (both version 17.0 and 17.2). Whether we check the "Firewall" box or not, TCP port 22 is not allowed through the radio to the RoboRIO. We have discovered how to get around this by logging into the admin interface on the radio (port 22!) and using appropriate configuration commands to add port 22 to the list of ports allowed through.
While this appears to be a bug in the FRC Radio Configuration Utility, I have not gotten confirmation of this as of yet.
