Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 23-01-2017, 21:34
FRCTeam2906's Avatar
FRCTeam2906 FRCTeam2906 is offline
FRC #2906 (Sentinel Prime)
FRCTeam2906 is an unknown quantity at this point
Encoder questions - using DIO ports
We are attempting to use different encoders through the DIO ports on our roboRIO for both our teleop and auto programs. We have never used these in the past. When we run our code the motor runs without stopping once it reaches the set value. Any help or examples are appreciated.
Thank you,
Team 2906
Unread 23-01-2017, 21:44
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
Re: Encoder questions - using DIO ports
It sounds like you are not setting your motor input back to zero when the target has been reached. You would need to post your code to say for sure.
Unread 24-01-2017, 14:00
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
Agreed, assuming you can tell that the encoders are working and being read properly. Code?
Unread 28-01-2017, 23:53
We have attempted to print the encoder values to the drivers station but they always return as 0, does bot matter if the motor is running or not.
Link to code: https://github.com/FRC2906/Practice
Please take a look and see what you can find asap!
Unread 29-01-2017, 09:05
I don't see where you are outputting the encoder value, at first glance
Unread 29-01-2017, 13:45
I believe that is located on line 136 and 142 of our robot map
Unread 29-01-2017, 15:37
Robot Map is only called once. You should output the data in something called periodically, like a command.
Unread 30-01-2017, 10:23
Ok thanks. So now we can see the values in the smart dashboard but how do we use it? If we want to run an auto command that does something like: "drive strait until the encoder value is gresater than 1000. What would it look like? A while, if or something else?
Unread 30-01-2017, 11:52
wlogeais wlogeais is offline
FRC #2177 (The Robettes)
wlogeais is an unknown quantity at this point
Take a look at File -> new -> Example Robot projects... -> GearsBot.
The relevant code is within the ...team...commands package, namely DriveStraight.java and the team-subsystem methods added to support it.
Unread 30-01-2017, 12:10
Joey1939's Avatar
Joey1939 Joey1939 is online now
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Relevant PSA: https://github.com/Open-RIO/.gitignore
Unread 30-01-2017, 13:36
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Originally Posted by Joey1939 View Post
Please. It'll keep the size of the repo down, and it'll make committing and pushing take a shorter amount of time since there's not as much to move over.
Unlike that gitignore though, we do keep our IDE files so it's easier to import into other Eclipse instances.
