Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
Unread 30-01-2017, 13:20
RoboChair's Avatar
AKA: Devin Castellucci
Re: Tubing for ball intake
Originally Posted by Mike Marandola View Post
Is it just me or are people talking about 3 different things? The structural tube for a roller, gripping material to put on the roller, and urethane belting.
No, there is definitely 3 different conversations in this thread.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 30-01-2017, 13:21
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Yup, there are 3 different answers for an ambiguous question here...
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
Unread 30-01-2017, 13:47
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Originally Posted by RoboChair View Post
McMaster Carr specifically we use https://www.mcmaster.com/#5234k91/=1650h8o for our 1.25" OD rollers this year. Yes that is a 0.25" interference.
You cannot pull it on at all. You will need to use compressed air and someone with a reasonably strong arm.
If you do not fully understand I can make a youtube video tutorial on Wednesday.
A tutorial would be awesome! Have you tried soapy water/ Murphy's Soap? I know this may not be an ideal solution due to residual soap left after application, but it may just work...
Also I just ordered the components to try this out for myself... should be interesting.
Unread 30-01-2017, 13:51
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
You cannot pull it on at all. You will need to use compressed air and someone with a reasonably strong arm. Zip-tie/safety-wire one end of the tubing to an air nozzle so that you get a good seal. Next you must plug off your aluminum roller so that air can't flow through it. one person controls air flow, the other holds the tube and tubing and does the hard part. turn on the air and begin pushing the latex on to the aluminum, DO NOT FOR ANY REASON clamp your hand down on the aluminum tube underneath the latex(your hand should never be that far up anyway) or you will get a 100psi balloon animal with a desire to pop. Alternate the airflow on and off to let you move your grip lower on the latex.
We've found that if you put the air on the end you are trying to pull on to the roller you don't need to plug anything.
Can't tell you which way is faster, it may very well be that yours is...
2012-Present Wave Robotics Team 2826
Unread 30-01-2017, 13:57
RoboChair's Avatar
I feel soap would actually be counter productive, it would make it easier to slide off quickly if you mess up the order. But seeing as the latex is literally floating on air there isn't much that the soap would do.
I will post a reminder in our team slack to put the video together during our next meeting on Wed.
Unread 30-01-2017, 14:04
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
I was more referring to a non-compressed air approach, however, 250 thou is a lot to overcome for an interferance fit, even with an 'easily' yielding material. Probably not possible.
How do you adjust the ends of the rollers? i.e. move the last inch of the latex up to your mark on the Al tubing?
Unread 30-01-2017, 14:08
RoboChair's Avatar
Razor blade. If I want a 24" roller, I NEED a piece at least 28" long and cut to the 24" mark when I float the end to the right position. I will also demonstrate how we make segmented rollers with multiple pieces on one length of roller.
Unread 30-01-2017, 16:32
clydefrog88's Avatar
clydefrog88 clydefrog88 is online now
Sam
FRC #4087 (Falcon Robotics)
clydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the rough
Thanks! The devil is in the details, and I love to hear them.
FRC 364 - Mechanical, Operator, Driver (2005-2008)
FRC Machine Judge (2015,2016)
FRC 4087 - Engineering Mentor (2016-?)
Unread 31-01-2017, 07:49
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
We would appreciate that video very much as we are putting our intake together this week with the same set up for the first time.
Unread 31-01-2017, 12:34
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Another possibility for the "slide it on without air" option is to use hairspray. This is a common method used when installing motorcycle hand grips. Slippery when wet, sticky when dry.
The "sticky when dry" caveat, however, should not be ignored. A 20" wide roller has only the two ends of the rubber tubing to facilitate evaporation. Four sections, each 5" wide, however, might allow for fairly rapid evaporation of the hairspray...
Older, but still somewhat coherent.
Unread 31-01-2017, 12:42
RoboChair's Avatar
I might as well do a round belt welding video at the same time. What other intake and conveyor stuff would you like me to add to the to-do list?
Unread 02-02-2017, 11:33
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
How to make poly round belts have identical tensions so they don't 'wander' on the rollers.
Unread 02-02-2017, 12:44
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
If it's not too late, probably also replacing polycord tubing and belting - I've seen both designing for accessibility and forming the bands on the roller
Academic Student (Forever)
