Go to Post "Splet" is the sound a frog makes when it hits pavement at 187 feet per second. Don't ask me how I know. - dlavery [more]
  #31   Spotlight this post!
Unread 30-01-2017, 13:15
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: 2 gear autonomous
Originally Posted by Fields View Post
Same thing I said previously. You don't have 15 seconds for the robot to do it's thing. You have 10-12 seconds with the last bit of time eaten up by the pilot placing the last gear and spinning the rotor 3 times before auto ends.
I'm waiting for dropped gears and lift handles during the rush to get both rotors spinning. Should be fun
461 Westside Boiler Invasion
45 Technokats
  #32   Spotlight this post!
Unread 30-01-2017, 13:55
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by Waz View Post
I briefly thought of this too but then I read the following in the game manual:
ROTORS only start if GEARS are installed in ROTOR order: 1, 2, 3, and then 4. The order of GEAR placement within a ROTOR set is not important. To start ROTOR 1, the PILOT places the GEAR in the GEAR slot at the top of the STEAM TANK, opposite the stack light for ROTOR 1.
Steve
It's worth reading the Q&A's interpretation of its own manual quote: A82 - Please remember that "ROTORS only start if GEARS are installed in ROTOR order." In other words, you won't be able to start ROTOR 4 until all other ROTORS have been started, etc.
Our FRC Overlords are really not doing a great job on this subject. Certainly everyone agrees that Rotor N cannot actually engage before Rotor N-1. We also agree that the rotation count of the lowest unengaged rotor rezeros if it sits idle over 10 seconds (this doesn't, itself, preclude accumulating rotations when you're not the lowest unengaged rotor, though it's admittedly highest on this pile of loose mandates). A82 seems to think the former has the same meaning as the manual telling us the gears need to be installed in order. If the GDC actually means A82 instead of p23, it's unclear whether the A82 meaning forbids starting to accumulate rotations or just actually starting (engaging) the rotor. Alternatively, if you can't earn rotations on N before engaging N-1, then the question becomes whether you've completely lost Rotor N by rotating early or if you can still accumulate rotations after engaging N-1 [what Kevin said].
Similarly, if the GDC really does mean the current manual wording of installing in order, the description is still incomplete. The strictest interpretation of the current wording is actually that ever installing any gear out of order (by rotor) results in killing at least one rotor--which one is not clear. If you put your first gear on Rotor 2 and your second on Rotor 1, will Rotor 1 start (and will you get points for it)? If not, can you lift your first gear up and then get points for Rotor 1?
I have now resolved to get myself a Q&A code. The waiting is driving me nuts. And I'm sure I'm annoying Kevin.
  #33   Spotlight this post!
Unread 30-01-2017, 14:15
Waz Waz is offline
Strategy and programming mentor
AKA: Steve
FRC #2357 (System Meltdown)
Waz is an unknown quantity at this point
Kevin and Siri,
You both make good points and I agree that the manual and Q/A could be more clear on this subject. I took another read of both and it almost sounds like an alliance could do the following (not that I would recommend it) and still be within the rules and get credit for all 4 rotors:
1) fill rotor 2 with gears,
2) fill rotor 3 with gears,
3) fill rotor 4 with gears,
4) place a gear to start rotor 1,
5) crank rotor 2 to life,
6) crank rotor 3 to life, and finally,
7) crank rotor 4 to life.
I appears from my latest reading (ask me again later) that steps 5 through 7 could NOT overlap but 1 through 3 could and step 4 could be completed anytime before 5.
Thanks,
Steve
  #34   Spotlight this post!
Unread 30-01-2017, 15:09
Kevin Zhang Kevin Zhang is offline
FRC #3501
Kevin Zhang is an unknown quantity at this point
But you can add one gear, then take a gear from an alliance partner. In order for a team to be controlling the gear, all they have to do is touch it, so the gear can be placed on the ground. With finesse and extremely efficient autonomous as I can only assume the top teams will be able to achieve, a 3 gear auton is theoretically possible.
  #35   Spotlight this post!
Unread 30-01-2017, 15:16
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
That's a weird way to interpret
Originally Posted by 4.2 Match Setup
When a DRIVE TEAM loads their ROBOT onto the FIELD for a MATCH they may elect to:
A. pre-load one (1) GEAR in or on their ROBOT such that it is fully and only supported by the ROBOT.
Academic Student (Forever)
  #36   Spotlight this post!
Unread 07-02-2017, 17:16
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Originally Posted by arichman1257 View Post
G27. One-GEAR limit. ROBOTS may not control more than one GEAR at a time.
Violation: FOUL. If strategic, TECH FOUL and YELLOW CARD.
I mayou just be reading the thread here wrong but it seems add if this rule has been over looked.
It has not. None of the ideas discussed here would require holding more than one gear at a time.
  #37   Spotlight this post!
Unread 07-02-2017, 17:17
AKA: Patrick Mattin
Rookie Year: 2015
The rule you put in talks about match setup. His comment talks about controlling objects. And anytime you push an object in frc, you are controlling it.
  #38   Spotlight this post!
Unread 07-02-2017, 18:32
Nessie Nessie is offline
FRC #2702 (Rebels)
Nessie is an unknown quantity at this point
Not entirely true. Inadvertently contacting a gear is not considered control as long as it is not advantageous. The blue box under G27 talks about this.
If you do happen to accidentally push a gear closer to your lift's while carrying another its a dead gear. Scoring it afterwards could be seen as an advantage.
Also, the difference between herding and bulldozing is up to the discretion of the ref's, so keep that in mind.
  #39   Spotlight this post!
Unread 07-02-2017, 20:42
Siri's Avatar
Dare greatly
Actually, the original comments were indeed about match setup--namely putting a gear on the ground in contact with Robot A to make it easier for Robot B to run a 2/3-gear auton:
But regardless, no, to "push" an object does not inherently mean "control":
G27 BB. ...Examples of interaction with GEARS that are not “control” include, but are not limited to:
A. “bulldozing” (inadvertent contact with GEARS while in the path of the
ROBOT moving about the FIELD)
B. “deflecting” (being hit by a GEAR that bounces into or off of a
ROBOT).
Note that these definitions can and do change year to year (so there's no FRC standard), though this one has been somewhat perennial.
  #40   Spotlight this post!
Unread 08-02-2017, 12:41
rocketgamer102 rocketgamer102 is offline
FRC #2544
rocketgamer102 is an unknown quantity at this point
There is no way to do it for only 1 robot to do more than one realisticly. If all three robots can do a gear in auto, that is just as good as 1 robot doing three gears. Plus, in auto, the max amount of gears in play is only 6, three blue, three red. So, make three auto if you are prioritizing gears; left, right, and center lifts. It will make you an asset and possibly a pick for the finals.
  #41   Spotlight this post!
Unread 08-02-2017, 13:01
FRC #2702 (Rebels)
Two gears one robot is entirely doable.
  #42   Spotlight this post!
Unread 08-02-2017, 13:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The question is if it makes strategic sense, though. There's limited situations where this actually pays off. If you have a robot that can Hopper + High goal in auton, you almost certainly want to do that instead of 2 gear. In what situations does a 2 gear auton net you more points?
  #43   Spotlight this post!
Unread 08-02-2017, 13:20
FiM_Strategery's Avatar
FiM_Strategery FiM_Strategery is offline
AKA: Lead Strategy Guy
FiM_Strategery is an unknown quantity at this point
When you have :
Robot 1: Single gear
Robot 2: Double gear + shoot(?)
Robot 3: Hopper + High Goal
Double gear auto will be for high level play, district champs and good elim alliances.
