Go to Post With your eyes open, there are wonders to behold, keep them closed and all you will do is bump into walls. - Al Skierkiewicz [more]
Unread 30-01-2017, 15:56
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: FRC Facebook Messenger ChatBot 2017 Release
Worked well for me -- are you getting data from TBA -- I'm guessing so assuming that is where pictures are coming from?
How does the process to deploy the code work? I had before build season toyed with the idea of a Messenger bot (as a sort of website replacement/complement) but was testing Chatfuel (which is code-less). I like the idea of putting it in a repo and having more control there, but the other way is real simple for non-programmers and to deploy.
Unread 30-01-2017, 16:56
jaredhk's Avatar
jaredhk jaredhk is offline
Tried turning it off and on again?
AKA: Jared Hasen-Klein
FRC #1836 (The MilkenKnights)
jaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud ofjaredhk has much to be proud of
The process is a little bit involved because you need to first create a Facebook Page (if you don't already have one) and then enroll as a developer. All of this is fairly easy but still takes some time and effort.
If you want more specific info, let me know and I'll pass it on to the main developer.
Jared Hasen-Klein, Director of Team Operations
MilkenKnights.com | Facebook | Twitter | Instagram | Snapchat
FREE RESOURCES
Unread 30-01-2017, 17:14
technonerdz technonerdz is offline
FRC #2626
technonerdz is an unknown quantity at this point
Hey ngreen! Starting a Chat Bot on messenger is really easy. I created a Github repo and then I bought a domain name and a hosting plan to host the php files that my bots use.
First, I watched online tutorials on how to create Facebook Bots in php. After the first youtube video, my framework was done and I did the rest by myself. FRC bot uses The Blue Alliance API to get his informations.
If you want to take a look at the code, you can go to: https://github.com/FRC-Bot/FRCBot-ChatBot
