Go to Post Now, I either need to convince Mike Martus to start the webhug early (or move it back 1 hour), skip the webhug, miss the first part of the presentation, or just clone myself. - Andy Baker [more]
Unread 30-01-2017, 11:35
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
pic: Inventor Practice Progress
Unread 30-01-2017, 11:39
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
Re: pic: Inventor Practice Progress
Looks great! A couple of suggestions, the black rails on the outside seem like they might be a little weak between bearings. I'd recommend maybe adding some triangle cross beams to increase the structural rigidity in those squareish holes on those rails.
In addition you might be able to take some more weight out of the belly pan with a more efficient lightening hole pattern such as alternating triangles. Squares are not the most rigid of structures so you'll be able to remove more material with another pattern.
To take it to the next level maybe add mounting holes for electronics into the pan, in addition, if you have the capability with your manufacturing process, I'd recommend adding some flanges in there, flanges will increase structural rigidity by a remarkable amount.
Looks great and best of luck continuing on your robot design journey!
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 30-01-2017, 15:16
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Looking good. Might want to think about bumpers now and not later though. I am not seeing and good place for them to attach.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-01-2017, 15:59
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Are the wheels offset from center at all? Just looking at the picture it seems flat.
If you don't already have one, adding an offset on the wheels will reduces scrub and drastically improve turning.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
That is what those red plates on the corners are for
It isn't shiny enough.
Unread 30-01-2017, 16:01
Yeah it does seem flat in the photo
Yes, there is a 1/16" offset
Unread 31-01-2017, 04:12
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
It's great to see people practicing CAD! A couple questions and suggestions though. First, why so many wheels, and why custom wheels? Also, I'll echo what Anthony said about mounting bumpers. From what I can see, I don't think your frame would be able to adhere to 2017 bumper rules. I'll also echo what Zach said about beefing up the outermost plates. They look a little flimsy.
This may just be my eyes playing tricks on me, but is the plate the CIMs attach to just a flange off the bellypan? Or are those two separate plates? If it is one piece, I'm not sure how I feel about that. On one hand, it's probably light and sturdy, but if that bend is even slightly off of 90°, it'll wreak havoc on the gear mesh. Spur gears don't do well under even small amounts of angular misalignment. So if you have some way of precisely controlling the angle of that bend, go for it. But if you just have a manual brake, I'd steer clear.
In general, I'd say to always justify the complexity in your design. Complex and beautiful pocketing patterns may look great in CAD, but you've still gotta cut all that material in real life. Consider manufacturing when creating designs, and your fabricators will think much more highly of you.
Happy CADding!
